Corey's NB Journal
Corey
Re: Corey's NB Journal
Postby Corey » Sat Nov 14, 2015 1:06 pm
Yesterday I went on a trip up to Sydney to pick up some more parts including a 6 speed short shifter, Adaptronic Select ECU and some 6ul Wheels in 15x9 +36 rear 15x8 +36 front. I also received my RX8 injectors courtesy of crumpet :)
smy0003
Postby smy0003 » Sat Nov 14, 2015 1:16 pm
Looks mega.
I can't decide between an MS2 family ecu or the adaptronic.
What was your reasoning behined the adaptronic?
Sent from my GT-I9505 using Tapatalk
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Corey
Postby Corey » Sat Nov 14, 2015 1:25 pm
smy0003 wrote:Looks mega.
I chose Adaptronic for a few reasons. Firstly is because it is widely used amongst tuners in Australia which is very important when getting your car tuned, a lot of tuners may not use megasquirt so either a) wont be fully confident tuning it or b) will refuse to tune it. The service I have gotten with Adaptronic is excellent, very helpful in answering all the questions I had and even had videos for me to watch to understand some stuff more; and also because they seem to put a lot of development into car specific ecus, this ecu is a direct plug and play into my loom and specific to my car; for example theres certain problems with alternators on NB's which this ecu takes care of.
smy0003
Postby smy0003 » Sat Nov 14, 2015 5:47 pm
Hmmmm...
I'll probably end up with adaptronic simply because of the exchange rate. It puts the megasquirt in the same price bracket as an adaptronic and by all accounts the adaptronic is much more powerful, although, my NA8 doesn't need vvt or alternator control.
The megasquirt seems to have a lot of diy support through miata turbo, but I suppose having andy available is just as good if not better.
Sorry, I'm thinking out loud here.
Thanks for sharing your thoughts.
Corey
Postby Corey » Wed Nov 18, 2015 11:10 am
smy0003 wrote:Hmmmm...
That is true, there is diy support for the adaptronic also, and if you get stuck with anything I don't doubt the adaptronic team would help you with whatever you need.
Corey
Postby Corey » Wed Dec 02, 2015 10:13 pm
Tonight I've been working on some custom canards, trying to get the right shape and positioning. Will be doing some research into aerodynamics tonight which can aid in my design.
beavis
Postby beavis » Wed Dec 02, 2015 10:32 pm
cool
they look too steep, give it more of a gradual increase in angle rather than having the air hit a 45deg wall
Corey
Postby Corey » Mon Jan 11, 2016 7:52 pm
Still working on the car and more parts. I have a few things waiting to do to the car which I will document soon. I picked up some new wheels (again). Heres how it currently looks.
Looking to get new tyres for these and possibly massage the arches a bit more and adjust ride height according to new tyre size. Thinking either 205/50 Kumho KU36, 195/55 Toyo R1R or 225/45 Hankook RS3.
SileNceR
Postby SileNceR » Mon Jan 18, 2016 11:21 pm
Looks really neat, nice photos too!
HAD (sold 2010) 2000 Emerald Green Mica NB8B
NOW 2001 Brilliant Black NB8B
OTHER 2010 Mazda 3 BL MPS Luxury
smy0003
Postby smy0003 » Fri Jan 22, 2016 10:34 am
Looks super aggressive, usually the 15x8 +0 thing looks a bit big, but it really works on your car.
How is the gauge ring project coming along?
Corey
Postby Corey » Mon Feb 15, 2016 3:17 pm
Thanks guys.
smy0003 wrote:Looks super aggressive, usually the 15x8 +0 thing looks a bit big, but it really works on your car.
Very good, happy with how they turn out. Currently testing fitment for NA Gauge clusters. Will be released soon!
In other news I got a new Renown Monaco Rosso and installed it onto an NRG slim hub. I removed the clock spring and made small tab to contact the horn ring on the back of the hub, I also went ahead and put a 3.3 ohm resister into the airbag module to stop the airbag light from showing. Everything functions fine including the indicator cancellers and am very happy with it. I also got a 50mm hub spacer to bring the wheel closer to me.
I've also picked up a rear bumper that I cut out and I've been doing some photoshopping for what my car will look like soon with the lightyear fastback I am waiting to get (I used an autokonexion one in the render) also a rear diffuser and side skirts.
I also installed some QFM A1RM Brake pads which feel good so far!
mx5002
Postby mx5002 » Mon Feb 15, 2016 8:06 pm
That rendering looks badass.
Is that bumper cut photoshopped or is that how much you actually cut? Did you remove the rear bumper reinforcement
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64 :D
luzinit
Postby luzinit » Mon Feb 15, 2016 8:31 pm
I thought that was an actual imagelo and was gob smacked at how great your car looks! Looking really good mate.
Sent from my SM-G920I using Tapatalk
smy0003
Postby smy0003 » Mon Feb 15, 2016 8:33 pm
Corey wrote:
The stiffy is real
Corey
Postby Corey » Mon Feb 15, 2016 8:50 pm
mx5002 wrote:That rendering looks badass.
Thanks! This cut is from the rendering but is probably not far off what I actually cut, I will get a picture for you, my cut is almost dead even with the bottom of the reinforcement bar.
luzinit wrote:I thought that was an actual imagelo and was gob smacked at how great your car looks! Looking really good mate.
Thank you sir :P I hope to have it looking like this without photoshop soon!
smy0003 wrote:The stiffy is real
Hahahaha :lol:
Users browsing this forum: Bing [Bot] and 188 guests
