Bear's White NB8B Turbo "Snowie"
bear2230
Re: Bear's White NB8B Turbo "Snowie"
Postby bear2230 » Tue Oct 13, 2015 10:12 pm
Progress at last H-Beam Carrillo rods and JE 84.5mm 9:1 pistons in situ
http://fab9tuning.com/engine/pistons/
IanR
Postby IanR » Wed Oct 14, 2015 10:48 am
Excellent! Hope its all smooth sailing from here....
3 different turbo NB's in this single Garage Thread...viewtopic.php?f=57&t=67687
Postby NitroDann » Tue Oct 20, 2015 9:13 pm
You should be at about 300rwkw by now, whats going on !!?? :mrgreen:
bear2230
Postby bear2230 » Tue Oct 20, 2015 9:39 pm
NitroDann wrote:You should be at about 300rwkw by now, whats going on !!?? :mrgreen:
I will be happy with 200rwhp Dann. At least for a few weeks
Just waiting for some new studs for the turbo due tomorrow then hopefully sit it back in.
Hopefully catch can won't be needed but if we do I have prepared the sump and I have a cracker of a design for a square catch can :D
Postby NitroDann » Tue Oct 20, 2015 9:43 pm
PM me if you want a little eye dropper bottle full of Resbond for the inconel studs.
bear2230
Postby bear2230 » Sat Oct 24, 2015 8:58 pm
Turbo now all mounted up.
Getting close now and David kindly relocated that friggin stupid brake line that used to run right next to the turbo.
bear2230
Postby bear2230 » Mon Oct 26, 2015 10:38 pm
Starts and runs well. Will run on the dyno tomorrow to burn all the oil out of the exhaust.
speed
Postby speed » Tue Oct 27, 2015 8:17 am
Sweet. You didn't mess around there. Good work!
bear2230
Postby bear2230 » Fri Nov 13, 2015 9:22 pm
Back safely with me now and no more smoke :D :D
Will take it easy for a while but first impressions are "holy crap its fast" I think too fast for a road car. I will turn it down to 10psi for a while until I get used to it a little.
This should help with the heat but still need a better heat shield. Thanks Daz.
Also got rid of the horrible SE gear surround and fascia and replaced it with the lovely Roadster polished one and matching fascia. Thanks Kev :D :D
The American
Postby The American » Fri Nov 13, 2015 9:33 pm
looks like you've got some hook fitting to do!
Postby KevGoat » Fri Nov 13, 2015 9:41 pm
bear2230 wrote:Also got rid of the horrible SE gear surround and fascia and replaced it with the lovely Roadster polished one and matching fascia. Thanks Kev :D :D
Looks great with the RX8 gear knob!!
Also notice the front strut brace made a return :wink:
Postby Okibi » Fri Nov 13, 2015 9:51 pm
Such a sexy bonnet :mrgreen:
bear2230
Postby bear2230 » Fri Nov 13, 2015 10:04 pm
I have RX8 gear knobs on both cars now. Everyone loves rotors and the triangle shape feels good to me.
The strut brace is definitely pretty although I'm not 100% convinced it actually does anything and I have a set of blue hooks for the white car. The back Bear Hook is on but I'm having a bitch of a time getting the front standard hook off as some fool stuck a bloody big intercooler right where I need to undo the last bolt.
The American
Postby The American » Fri Nov 13, 2015 10:18 pm
bear2230 wrote:...but I'm having a bitch of a time getting the front standard hook off as some fool stuck a bloody big intercooler right where I need to undo the last bolt.
so said my knuckles earlier this evening!
ManiacLachy
Engaged
Postby ManiacLachy » Sat Nov 14, 2015 4:09 pm
Okibi wrote:Such a sexy bonnet :mrgreen:
x2. So very very jealous.
