Juicy's SE
- davekmoore
Re: Juicy's SE
Still struggling to understand why ECU manufacturers expect owners and tuners to complete the development of their product
- Vehicle: ND - RF
Re: Juicy's SE
A short thread-jack.....
I would be interested in 'package' although how adaptable is it to differences in the typical 'bolt-on' additions to an SE?
Would a formal tune still be required to get the best?
Would you need to have a WBO2 fitted?
Also very interested in your opinions on this too as you are one of the few tuners with extensive experience on all three of the most commonly fitted ECUs for MX5's.
Probably best to start a new thread on ECUs and the types of packages you can offer to keep it all neat.
NitroDann wrote:I guess the next step is working out if people are interested in Elite plug and play setups which include a PnP harness with PnP boost control and the injectors/map to go with it and run your car like stock but with tonnes more power and drveability with almost no tuning. I have the harness info, the ECU side of the harness info, pinout combination that works with that harness, and a base map that works flawlessly like stock with a specific set of off the shelf large injectors.
Lokiel wrote:Thanks for posting that explanation Dann, please post it in a separate thread too (with an easy-to-search-for title) to make the information easier to find and post it in MT.net too.
I've been meaning to ask you too to post your opinions on ECUs since you've seen a few now (MegaSquirt, Haltech, Adaptronic).
- Vehicle: NA6 - Turbo
Re: Juicy's SE
NitroDann wrote:I wanted to put an update in for this car...Dann
Technical people rarely have a say in when a product is released..They are just told to make it work once in the field..This is not new as some of the world's largest computer companies have been doing this for decades and even some of the best computer systems the world has seen suffered from the released too early syndrome.
We had an Elite 1500 installed four odd months ago on our SR20 powered MX5 and it was not easy going in that there was no base tune configuration available and previous configurations would not migrate..In short the base tune had to be configured manually.
Had we had an LS1 in our MX5 it would have been far easier as the Elite 2500 (6/8 cylinder version) was released four months before the 1500 (four cylinder version) and the tuner had already gone down the LS1 engine configuration path.
In short this tuner can now do SR20 and LS1 Elite base setups quite easily.
This brings me to Dann's experiences with now two MX5s and the functionally excellent Haltech Elite 1500.
If you are thinking of installing this ECU on your Mazda engined MX5 and you want something that is turn key go to Dann as he has done the hard yards and has already got his IP (base maps) invested in something that should work the first time.
Speaking from experience, if you install one of these ECUs and your tuner has not done one before, expect delays.
Again, I think this is a good product in that connections are managed via software rather than hardware which means the ECU can be very flexible and future changes in functionality could be just a firmware download away.
Haltech support is very accommodating but user documentation is still in short supply so all the more reason for engaging someone like Dann if you want to install one of these ECUs.
Stuart..
Re: Juicy's SE
Thanks for your insight, I agree in every way.
The car is back with its owner cirrently at the start of its 1000km drive home. Another NitroDann turbocharged Mazda to add to the list. I must have done over 10,000rwhp worth of them by now.
Hopefully he can give us some feedback tonight.
- ManiacLachy
Re: Juicy's SE
You're assuming he'll stop driving after he completes the 1000km drive home?
Can't wait to hear the report on this car!
Re: Juicy's SE
8L per hundred so far on the journey home. (info via text)
291km for 23.6L.
291km for 23.6L.
Re: Juicy's SE
What do most modded SEs get, btw?
Anyone... everyone?
Anyone... everyone?
- ManiacLachy
Re: Juicy's SE
With exhaust and intake, I get between 7.5 and 8.5, depending on use. Low 8s most of the time
Re: Juicy's SE
I've never gotten that good before.
Sent from my SM-G928I using Tapatalk
- ManiacLachy
Re: Juicy's SE
98.
- davekmoore
Re: Juicy's SE
8.5L on 98 on a mixture of road driving. 30.0L on the track on E85.
- Vehicle: ND - RF
Re: Juicy's SE
~8L/100Km on 98 with mixed driving, stock performance wise apart from a 2.5" exhaust.
Re: Juicy's SE
I must have a lead foot
Re: Juicy's SE
Anyone reading who has a standalone ecu on an SE who doesnt mind sharing their economy?
Users browsing this forum: No registered users and 83 guests
