Postby Magpie » Sun Sep 27, 2015 6:21 pm
Thanks G! Could de wing the car and find out at QR one day just for curiosity. I was dewinged once before but did not change the straight line speed and it did feel a bit witchy in the high speed corners.
Not much chance of find more seconds in 2015, will find them in 2016!
Car is back at Plus getting a once over and tune tweak for WTAC so no more time to play with it :(
speed
Postby speed » Mon Sep 28, 2015 9:34 am
Congrats Mark, look forward to seeing you and your car at wtac.
Postby Magpie » Mon Sep 28, 2015 11:14 am
Between now and October 13 the following will be done;
1. New splitter that extends 50mm beyond the front.
2. Fit 10 kg front springs and OEM front sway bar (and corner weight).
3. Fit Winmax 6.5's to the front.
4. Replace the current headlight setup.
5. Alignment.
6. Pre track service/inspection.
7. Relocate coolant overflow (issue found after item 4).
8. ITB duct utilising the Jetstream headlights (now possible because of item 4)
Red - to be done
Green - done
Orange - in progress
Postby Magpie » Tue Sep 29, 2015 9:21 am
Had a look at one of Gools videos of the Clubman
My issue is that I’m washing off too much speed before the corner and accelerating to the apex whereas Gools is turning in and maintain speed to the apex. However I'm happy with my apex speeds but need to work on the brake into the corner and not need to accelerate to the apex. If I can get this right there is a lot of time to make up at 2 and 6.
Trackphotos
Postby Trackphotos » Tue Sep 29, 2015 5:02 pm
You've got time to gain at t1 too. Same vmin as me but with the advantage of aero and less weight. Same principle, brake less and use the turnin to wash the last few kmh off before the apex, then power out.
Postby Magpie » Tue Sep 29, 2015 5:07 pm
Yep your Clubman time is next on my bucket list :) Then 1:04.60 followed by a 1:03 all in 2016 for QR Clubman as well as adding Mt Cotton hill climb times and possibly beating my previous PB at Lakeside.
My previous PB was a 1:08.8768 on 17/02/2014 previous to that it was a 1:11.7167 on 18/03/2013. These times should not be too hard to beat....
Trackphotos
Postby Trackphotos » Tue Sep 29, 2015 6:16 pm
You're only 8 hundredths off my clubman time, that'll fall next time you go out. The other times should be pretty cruisey to catch, although it's been a while so you might have to work up to them. Lakeside can be daunting to get time down on.
Postby Magpie » Tue Sep 29, 2015 7:32 pm
I don't normally run at Lakeside, it is more a confidence thing than anything else. The car has never been run at Lakeside in its current form. In 2014 it was just after the engine was in and it was a shakedown cruise.
Postby Magpie » Sat Oct 03, 2015 7:45 pm
5. Alignment.
Red - to be done
Green - done
Postby Magpie » Sun Oct 04, 2015 7:51 pm
5. Alignment.
Red - to be done
Green - done
The car has lost over 50kg including driver since 2013. The WTAC class weight is 940kg for a NA6. It would be interesting to see what it weights without the hardtop and roll bar and no fluids. Notwithstanding it was a pain to corner balance today, decided to not change springs/roll bar until after WTAC.
Splitter V4 is not road legal, it is deceptive but it does stick out 40mm more, did not go the full 50mm, it actually looks legal...
I used the same material as V3 so it will only be a little bit heavier. Essentially I traced the existing one, drew a line 40mm parallel to the back and moved the splitter down and traced the new bits.
ImageDSCN2785 by Eipeip, on Flickr
ImageDSCN2789 by Eipeip, on Flickr
This would have to be my most used cutting tool.
ImageDSCN2791 by Eipeip, on Flickr
All cut out
ImageDSCN2792 by Eipeip, on Flickr
Time to bend the edging, same template as V3.
ImageDSCN2793 by Eipeip, on Flickr
ImageDSCN2795 by Eipeip, on Flickr
ImageDSCN2794 by Eipeip, on Flickr
Next step was the other half of the edge
ImageDSCN2796 by Eipeip, on Flickr
Test fitted on the new splitter
ImageDSCN2798 by Eipeip, on Flickr
Also removed some more previous 'additional' wiring.
ImageUntitled by Eipeip, on Flickr
Postby Magpie » Tue Oct 06, 2015 9:44 am
7 days before leaving for WTAC.
5. Alignment.
Red - to be done
Green - done
Blue - Not happening before WTAC
Left the MX5 in peace yesterday (apart from a trip on the trailer), detailed the Amarok instead.
The splitter (V4) has about 95mm of clearance at the front and more importantly no clash when loading on the trailer. This photo was taken with the front wheels just on the trailer and the trailer at full tilt, it is close.
ImageIMG_1072 by Eipeip, on Flickr
Postby Magpie » Wed Oct 07, 2015 10:58 am
Its official I have carport CP32 for WTAC 2015, pop in and say hi if you get a chance.
ImageWTAC by Eipeip, on Flickr
plohl
Postby plohl » Wed Oct 07, 2015 11:12 am
You spelt c3p0 wrong.....
plohl
Postby Magpie » Wed Oct 07, 2015 11:16 am
Bad bad bad bad plohl. Do or not do there is no try...
mx5002
Postby mx5002 » Wed Oct 07, 2015 12:03 pm
Lots of progress.
Will definitely drop by your garage at wtac.
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64 :D
Users browsing this forum: No registered users and 17 guests
