Steampunk wrote:Some simple things we can tackle for those who aren't mechanically minded or don't have appropriate tools/equipment:
- engine/gearbox/diff oil change
- engine oil filter change
- check/replace spark plugs
- check/clean soft top water drain
- the good ol' igntion timing bump for NA's
- rotate wheels
- replace coolant
- re grease window mechanism
- replace bulbs
And so on
MXO005 wrote: I've gone and bought a roll bar from Automotive Plus this morning. Anyone else done the same thing and willing to lend each other a hand and hopefully cut down on the number of mistakes?
Magpie wrote:Could set a TV up in the shed, just need an antenna.
