Play fair mate, give us a fighting chance at least
cookie wrote:Didn't see you had a build thread! (I'm the helpful guy who did all the dirty work to remove the original motor ;) )
How's the itb design going?
3gress wrote:cookie wrote:How's the itb design going?
So the rumours are confirmed? I knew something was in the works, just had the motors mixed up. If the exhaust design is anything to go by, the inlet should be something to behold.
Subbed and keen to see the results. Awesome work mate.
project.r.racing wrote:I'd be more worried about the bonnet shutting with a FS inside the bay.
3gress wrote:If you do decide to follow the not so secret idea consider having the adaptor made to angle the throttle bodies up around 10° for brake master clearance. I do believe there are significant gains to be had with a properly engineered individual throttle body system. It all comes down to runner length and an efficient plenum design with calculated volume to satisfy engine VE. Look toward BTTC touring car setups, hayabusa engines etc. It is only the clearence problems with rhd mx5s that spark forum wars over the effectiveness of multiple butterfly systems. I'm currently trawling the web looking at carbon composite suppliers to have a crack at a decent plenum design. Search for the miatabusa project and peruse their own ideas on plenum design for inspiration.
Magpie wrote:Contact Automotive Plus they have an airbox to suit Jenvey ITB's that has 110mm trumpets and fits in the OEM engine bay and retains the OEM booster/clutch. Plus the panel filter used is available off the shelf. The airbox could even handle moderate boost!
madjak wrote:For the flange, you can just get a new one waterjet cut. I think mine cost me $70 out of 12mm aluminium. With the waterjet cutting, you'd need to undersize the threaded holes and them drill them to size on a bench press. The other way to do it is similar to my build thread which is weld a new flange onto a Honda intake manifold. Not the same sound as ITB's but would make good power.
project.r.racing wrote:The FS engine is a little taller than the BP/B6 engine. So you might find you have less clearance issues over normal MX5s.
madjak wrote:Actually looking at the FS head, I think you'd be damn close to just bolting on a Honda intake. The FS has the injectors in the manifold similar to the Honda, so you could get a Skunk2 intake and just drill the FS holes into the existing intake and bolt it up. My guess is that there is only one hole (the bottom center) that would be an issue, and that one would need some sort of bridge piece made up.
here is the link to the page on my build thread: There are some photos there of the manifold I'm talking about.
http://mx5cartalk.com/forum/viewtopic.php?f=57&t=68537&start=45
hks_kansei wrote:project.r.racing wrote:I'd be more worried about the bonnet shutting with a FS inside the bay.
Slam it hard enough and it should self clearance
Users browsing this forum: Bing [Bot] and 8 guests
