Adaptronic owners thread
rascal
Re: Adaptronic owners thread
Postby rascal » Mon Sep 07, 2015 1:48 pm
Good. Seems to know his stuff, is quick to get the tune right, and well priced.
Only downside is you sometimes have to book a fair bit in advance as he can get pretty busy. Though guess that's also a good sign that he is in demand..
Sage
Postby Sage » Mon Sep 07, 2015 2:58 pm
strange that he will look after you though not new customers :(
What are your specs rascal? Did you have any trouble with idle/cold start? that is what they said can be the issue.. why tune it 4 times? (you keep modding the car?) :)
Can you give me a ballpark figure on your first tune?
Considering tuning it myself now..
Thanks for the info!
rascal
Postby rascal » Mon Sep 07, 2015 3:59 pm
Yes, kept modding... 8)
I've sent you a PM
Postby Lokiel » Mon Sep 07, 2015 9:17 pm
Sage wrote::
... sounds like they haven't tuned any of the new Select ECUs with alternator input, this REALLY helps with idle control when the A/C kicks in - no more stalling.
Roadrunner
coyotes after you
Postby Roadrunner » Mon Sep 07, 2015 9:36 pm
Also second the current gen standalone adaptronic.
Nitrodann just installed a select adaptronic in my SE and it hasn't stalled. Not once.
Cold start and idle is perfect. Throw any load at it, AC, headlights etc solid as.
MeepMeep
Sage
Postby Sage » Tue Sep 08, 2015 11:12 am
how do you tell if its a second gen adaptronic? :)
Postby Lokiel » Tue Sep 08, 2015 2:21 pm
The new standalone Select ECU is shown on the left, sitting on top of the OEM ECU (it's tine) - the one on the right is the original piggyback Select ECU and is slightly larger than the OEM ECU.
timk
Postby timk » Tue Sep 08, 2015 4:36 pm
The "current" NB8A ECU is still the same size as the one on the right, but it doesn't have provisions to connect through the OE ECU.
Trackphotos
Postby Trackphotos » Tue Sep 08, 2015 5:08 pm
The current nb8a standalone ecu is the same size as the smaller one on the left in that pic Tim.
Sage
Postby Sage » Wed Sep 09, 2015 11:28 am
thanks i have 2nd gen then :)
Roadrunner
coyotes after you
Postby Roadrunner » Wed Sep 23, 2015 9:35 pm
Does anyone know if the standalone select ecu's control the EGR valve or is it a solenoid activated on throttle input? (Ie open during part throttle, closed at idle and full throttle)
I assume if it's no longer controlled by the adaptronic ECU it would be permanent closed?
MeepMeep
sailaholic
Postby sailaholic » Wed Sep 23, 2015 10:57 pm
It's controlled by the ECU on a na8. I can't comment on the rest as I've removed the valve.
Postby Lokiel » Wed Sep 23, 2015 11:05 pm
Roadrunner wrote:Does anyone know if the standalone select ecu's control the EGR valve or is it a solenoid activated on throttle input? (Ie open during part throttle, closed at idle and full throttle)
Adaptronic ECU doesn't control the valve, typically you use block-off plates (eg. http://www.trackspeedengineering.com/Trackspeed-EGR-Blockoff-Plates.html)
I can't comment on what the default state is (open vs closed vs indeterminate) so block it off (I have a blockoff plate sandwiched between the block and EGR valve so it looks stock.
sailaholic
Postby sailaholic » Thu Sep 24, 2015 7:18 am
Woops sorry I was thinking the purge valve on the charcoal canister.
Roadrunner
coyotes after you
Postby Roadrunner » Thu Sep 24, 2015 4:09 pm
Excellent! Thanks guys :beer:
MeepMeep
