Bullet superchargers
Novice1
Re: Bullet superchargers
Postby Novice1 » Tue Jun 30, 2015 9:31 pm
Dan wrote:I've been reading that thread on Miata.net you quoted from with interest, some cool features and I'm looking forward to hearing how you go with it.
I've also got ECUtek and have been meaning to speak to my tuner about getting the AutoBlip feature enabled to try it out.
Probably needs some testing to dial in the pedal percentage map but I think it would be a good feature if it's tuned right.
Seems like a simple enough map if it's the same on the MX5 (this is the Subaru one) :
To quote my mechanic. Launch control " A bit of a wank" Flat shifting he loved it, auto blipping he also liked. Once setup most features are controlled by cruise control select buttons. My mechanic races V8 Commodores , his car just under 600 hp. He really liked the features that the Ecutek can provide.
Novice1
Novice1
Postby Novice1 » Wed Jul 01, 2015 8:53 am
Dann in case u haven,t seen.
Flat foot shift and downshift auto blip .
http://youtu.be/MuLRmzaNjUk
Launch control is actually awesome . My mechanic had DSC turned off when we tried it. With DSC engaged similar to this clip.
http://youtu.be/e4UxYIwPnFQ
Novice1
Dan
Postby Dan » Wed Jul 01, 2015 9:09 am
Nice, I hadn't seen the videos. Cool to see the flat foot shift and AutoBlip features working. I'm already a convert to the idea as my Evo has a dual clutch transmission that does both of those things with paddles :)
Do you know if the AutoBlip and Flat foot shifting are able to be switched by using the cruise button to go to a different map?
The reason I ask is that on my Evo I know that there are only some maps are able to be preset and switched using the cruise control buttons (fuel, timing, injector scaling etc..) but a lot of features aren't. If I'm going to the track to test out some features it would be good if I could try the AutoBlip map a couple of different ways or maybe turn it off if I want to.
Novice1
Postby Novice1 » Wed Jul 01, 2015 10:36 am
Dan wrote:Nice, I hadn't seen the videos. Cool to see the flat foot shift and AutoBlip features working. I'm already a convert to the idea as my Evo has a dual clutch transmission that does both of those things with paddles :)
My mechanic has the written info on Ecutek features eg auto blip etc. Its his day off today. I will email him for the info.
Pretty sure though once its setup tho all features are activated bycruise control and up to four features, maps can be stored. When taken for a drive Chris just oressed cancel button on cruise controland used select +or - to access features. Sometimes u held down cancel button for 1 second sometimes 2 secs.
I will email u instructions when I get them.
Novice1
Sailor
Postby Sailor » Wed Jul 01, 2015 4:03 pm
Plenty of info on the EcuTek website.
You can download those instructions from there.
Autoblip is cute but you'd only use it on trackdays..maybe
Rob
Novice1
Postby Novice1 » Fri Jul 03, 2015 5:31 pm
trickytrev wrote:Mate that sounds better I've got i think 267 torque can wait till i get mine back with major up grade form Suli
trev,
what gearbox oil are you using, also engine oil.
Cheers Ron Novice1
Novice1
Postby Novice1 » Tue Jul 07, 2015 9:27 pm
Another reflash today. Feels quicker, 3 rd gear now has quite a lot of punch. Friday's reflash 218 hp, today's I think wud be more.
Novice1 aka Ron
Novice1
Postby Novice1 » Sun Aug 16, 2015 5:34 pm
Novice1
Sideskirts, Garage VRy lip.
Novice1
Postby Novice1 » Sun Aug 16, 2015 5:44 pm
Car getting detaiked next week. Will post up pictures when done.
Novice1
Postby Regie » Sun Aug 16, 2015 8:30 pm
good to see you are pleased with the results she is putting out :D
Where did you get those side skirts from? they look sick!
Novice1
Postby Novice1 » Sun Aug 16, 2015 9:22 pm
Regie wrote:good to see you are pleased with the results she is putting out :D
Rev 9, Jetstream Clubman http://rev9autosport.com/jet-stream-clu ... s-976.html
They are quite aggressive looking.
Novice1
