Here's the scale, top to bottom:
1: Not Low. Stocks Springs. Allows you to run over small animals without damaging bodywork.
2: A Bit Low, coilovers on the maximum height, good for driving on normal roads probably not really 'Low', some critters are dangerous to your body work.
3: Low, you can still drive on the street, but it's an obstacle course. most critters are a danger to your car's appearance.
4: Yo-momma's-so-fat Low. You might get stuck on twigs, you definitely will get stuck on your driveway, speed humps, gutters, sharp crests, dirt and long grass. You will become good at "drift stitching"
5: Internet Low. This is how Low the internet says you need to be. You remove the springs completely, and weld the suspension in place with the car resting on the ground. Shave excess material from the bottom of the car to make it lower.
So! How low (or not) are you?
Is this as low (or not) as you want the car to be? Why? (Looks, Handling, 4WDing, etc)
____
Being my idea, I'll go first;
I'm #1, I want to be #2.
I actually like being able to drive down dirt tracks, so I'm not even sure I want to go down to #2, the main appeal is increased spring rates for the crappier roads. If I planned on never driving on a dirt road again, I'd go for a #3 on looks.
