D.A.M's NA6
- D.A.M
Re: D.A.M's NA6
Update!
car is running perfectly with the help of Jelzahar and my good friend Brett. Replaced the Master and Slave cylinders today and its all good again
- D.A.M
Re: D.A.M's NA6
Only issue I've found thus far is, as i drive and hit about 2500-3000rpm the clutch pedal will vibrate a bit. Other than that its all fine. Is this an issue i should worry about?
- D.A.M
Re: D.A.M's NA6
ok so the T.O bearing was sitting on the pressure plate, luckily i had another genuine Mazda T.O and swapped that in (so the gearbox had to come out..again) and there is still vibration in the pedal but not as much which helps. After research its either the lightweight flywheel causing some vibration or the clutch bedding itself.
But overall, the car drives fine and the new 4.1 Torsen T1 diff feels amazing compared to the standard NA6 4.3 open center diff.
- slug_dub
Re: D.A.M's NA6
Is all that gearbox removal going on on the ground?? Thats a lot of removals in a short space of time
- D.A.M
Re: D.A.M's NA6
First one on Anzac Day was in a pit with the help of 3 other gents. Todays was on the ground with Jamal (champ). can officially say it was an experience and a half and we agreed its all part of the fun
- D.A.M
Re: D.A.M's NA6
From Downshift today with Brett Droder, photo was taken by MBF Productions
Also got in at the start of this video
https://www.youtube.com/watch?v=bVx5oj8xJ6s
- D.A.M
Re: D.A.M's NA6
Acquired a 24mm adjustable Superpro front anti sway bar and SuperPro bushes to aid the handling compared to the old stock bar and bushes
- D.A.M
Re: D.A.M's NA6
New update of late, about 80% of the time when slowing to a stop, the cars revs wont stop at 800-900 region but dip down to about 100-200 revs and jump back up to the good idle rev range of 900 ish revs. sometimes if i clutch in a a specific time the car will stall.
otherwise runs well as per usual.
must investigate but guessing there is an air leak happening somewhere as Nitro Dann mentioned in another thread regarding some odd readings my air/fuel ratio gauge was giving me.
Will update soon with progress reports.
- D.A.M
Re: D.A.M's NA6
fixed the above issue as there was an air leak in the intake! so runs great now
- D.A.M
Re: D.A.M's NA6
- D.A.M
Re: D.A.M's NA6
- slug_dub
Re: D.A.M's NA6
Photo fail here Dion
- D.A.M
Re: D.A.M's NA6
ok for some reason its showing perfect on my oc, but its not showing on my phone, will try and fix this
- D.A.M
- D.A.M
Re: D.A.M's NA6
The Achilles ATR Sport tyres are off and brand new Federal 595RS-R's in the 195/50R15 size are on, just in time for the QLD MX5 club track day at Lakeside too.
Must admit the ATR's are a cheap tyre for a bit of fun, but the 123's I had previously were definitely better, although overall after a few mountain runs, the Federal's are the top pick.
Users browsing this forum: No registered users and 190 guests
