Let's try this again - Alex's NB
rxmx
Vehicle: NA6 - Turbo
Re: Let's try this again - Alex's NB
Postby rxmx » Thu Dec 19, 2013 12:46 pm
Nice effort Alex, def a high 12 in there just need a decent launch with a lower 60ft, easier said than done with the mx5. Looking forward to seeing what this thing makes with some more boost :)
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
A.Chen89
Postby A.Chen89 » Wed Jan 22, 2014 9:16 pm
Soooo here's the flip side of owning a turbo MX-5.
Met up with a couple if forum goers for a run at the drags - was good seeing everyone giving it a hit!
First run ran a sloppy 14.1, second run I dumped it from 5500 and bam! Broken driveshaft. Sheared off cleanly into two.
Looks like the Borg is very good at doing it's job.
Better the driveshaft than the gearbox though, hopefully will get it up running again soon.
Anyone got a spare shaft ;)?
Snowmotion
Postby Snowmotion » Wed Jan 22, 2014 9:23 pm
Bugger Alex. Hope you get it running soon.
A.Chen89
Postby A.Chen89 » Wed Jan 22, 2014 11:14 pm
Not the end of the world.
On the bright side, found out it weighs ~1160kg with a full tank of petrol, rollbar, power steering, A/C etc. not bad!
A.Chen89
Postby A.Chen89 » Mon Jul 13, 2015 10:28 pm
Bump from the dead.
Sorted out some teething issues and found some time to play cars again. Originally tracked this last October at Circuit Club but had overheating issues with no under tray and a seized sliding pin in a front brake caliper.
Also had a corroding radiator as the result of electrolysis which hopefully I've fixed now.
Went to a Circuit Club track day on Saturday and managed to drive the car trouble free all day! Oil temp gets a bit too high but hopefully some ducting will sort that out.
I installed a beat rush under tray but still haven't closed up the sides so I believe the air is passing through mostly the radiator but not going through the oil cooler. The cooler isn't in the best spot but should be able to make it work - the AC condenser also doesn't help.
And here's a video!
Boost is great, still learning how to drive the thing as my lines weren't clean as before but its a start! I don't think I'll be tracking this in the middle of summer.
Apu
Postby Apu » Mon Jul 13, 2015 10:41 pm
Water-methanol injection Alex! In fact, you can just use it to run distilled water.
A.Chen89
Postby A.Chen89 » Tue Jul 14, 2015 8:08 pm
Hmm haha that seems a bit extreme. I'll probably forget to top the tank up
Apu
Postby Apu » Tue Jul 14, 2015 9:40 pm
Nothing wrong with that...just lose some power (it is noticeable though!).
Once I'm finished with the water-meth mix, I'm just going to use distilled water and see how that goes, and just keep water-meth for track days.
A.Chen89
Postby A.Chen89 » Thu Sep 15, 2016 12:02 am
Thread revival!
Still alive and the car still goes well; albeit after having fixed a couple of oil leaks and putting in a new Kaaz 1.5 way LSD. The Borg still spools strong with its signature kettle boiling sound.
Still have a bit of an issue with oil temps on the track since the cooler is located on the steering rack but working on a solution!
Also had some ducting made up; made a world of difference at Wakefield! Temperature never moved above 90 degrees on the Queen's Birthday public holiday track day.
Image13422400_859246054208582_568875544756016692_o by Alex Chen, on Flickr
Image13442479_859248354208352_12126914435947711_o by Alex Chen, on Flickr
Is it me or is every other car massive? :lol:
Image13483055_859246100875244_9015027051126992957_o by Alex Chen, on Flickr
Image13490604_859246264208561_6355126117511907336_o by Alex Chen, on Flickr
Image13490730_859242887542232_3762646020957775838_o by Alex Chen, on Flickr
Also did a bit of drivng recently, managed to do Thunderbolts Way and ended up at Walcha. Great drive but the surface was a bit less then desirable in certain sections.
Image14054403_10153657815440740_2687696765462023738_o by Alex Chen, on Flickr
ImageIMG_8497 by Alex Chen, on Flickr
Here's a couple of shots from a Putty run, check out the variety of cars!
ImageIMG_8990 by Alex Chen, on Flickr
ImageIMG_8991 by Alex Chen, on Flickr
ImageIMG_8992 by Alex Chen, on Flickr
Hopefully looking at doing another day at Marulan sooner or later as well as giving South Circuit another go again.
Apu
Postby Apu » Thu Sep 15, 2016 9:48 pm
That's fine looking Integra in those pics!
Nice views on the drive to Walcha. I miss going out on group drives...should get onto it again!
luzinit
Postby luzinit » Fri Sep 16, 2016 9:25 am
Car is looking fine as usual! Good to see you really getting to use it. I just bought some work wheels, which are polished with Gold centres. Wasnt really sure how it would look on a silver car but just saw your pics again and actually think it will look great!
Sent from my SM-G920I using Tapatalk
Apu
Postby Apu » Fri Sep 16, 2016 10:16 pm
Just got to keep them wheels clean!
A.Chen89
Postby A.Chen89 » Fri Sep 16, 2016 10:28 pm
Hehe cheers fellas
Might need to grab some 6UL's apu, then you won't notice!
Postby bruce » Sat Sep 17, 2016 12:36 pm
Nice setup.
Has the silver coating on the turbo manifold lasted? Does it still look good?
A.Chen89
Postby A.Chen89 » Sun Sep 18, 2016 12:08 pm
Yep the ceramic coating has held up well; still looks the same as the day it got coated
