I'm particularly looking for the sections on standard times and processes for removing, overhauling and replacing a motor.
Even more specifically looking for the correct Mazda authorised method of adjusting valve clearances.
Anyone got Mazda workshop manual for SE?
Moderators: timk, Stu, -alex, miata, zombie, Andrew, PUR157
- davekmoore
Re: Anyone got Mazda workshop manual for SE?
It's unlikely Mazda released a whole new manual for the SE (Mazdaspeed Miata in the USA, and Roadster Turbo in Japan)
It's most likely that a simple appendix was released for the SE that was tacked onto the end (or inserted into the middle ) of the existing NB manuals.
I would be searching the web for downloadable NB8B manuals from after whatever year the SE was released, you might get lucky and find one has the appendix.
There is a thread on the forum somewhere with links to manuals, you might need to hunt for it since it's pretty old now.
If you're in a bind, i'd download one of the NB8A manuals and use it for the method, since the SE shared the same engine as the 8A (just with a turbo, and different cam specs)
While the standard NB8A clearances may be different, the method to check them should be the same.
- Vehicle: ND - RF
- davekmoore
Thanks. I'd certainly settle for an OEM NB8A workshop manual if I could find one.
davekmoore wrote:Thanks. I'd certainly settle for an OEM NB8A workshop manual if I could find one.
PM me your email address and I'll send you one when I get home (or tomorrow night)
Or send me a pm
Dave
Sent from my iPad using Tapatalk HD
Dave
Dave
Ti SE
(WA Based)
Dave
Ti SE
(WA Based)
Nevyn72 wrote:https://drive.google.com/folderview?id=0B3YbfB30DxW0bEdwS0xSNGVXMzA&usp=sharing
And if you use Firefox instead of Internet Explorer you can save the whole MSM (SE) factory manual, or which ever parts you need.
- Learner Driver
Try google or torrents most of the mx5 manuals avial that way
Return to “MX5 Technical Guides”
