Turbo exhaust- effect of adding resonator
Paulus
Vehicle: NA6 - Turbo
Postby Paulus » Wed Jul 08, 2015 10:03 pm
Hi All,
I've got a straight 2.5" exhaust with a 200 cell CAT and a single resonator under the boot.
The issue is it drones quite a lot and tbh, I miss hearing my engine.
Would adding a resonator help? Where should I install it? After CAT? How would it impact turbo performance?
Any advice would be appreciated.
td05-16g, megasquirt, custom zorst, msdroid tablet etc
Re: Turbo exhaust- effect of adding resonator
Postby NitroDann » Wed Jul 08, 2015 10:44 pm
Fitntge largest body straight through perforated core muffler that you can possibly fit in a different length to the current one
No performance change or tune required.
speed
Postby speed » Thu Jul 09, 2015 9:52 am
Dann, just so that I learn the science behind it. Is it because a resonator is basically a straight thru muffler, so fitting a longer muffler is a neater way of doing the same as adding a resonator?
Postby NitroDann » Thu Jul 09, 2015 10:04 am
When you say resonator I assume you mean a hotdog.
A straight through perforated core muffler is just a hotdog with much much more sound deadening material.
You want a different length to cancel resonance at different frequencies to your current muffler rather than the same length and still ending up with an rpm band which the mufflers do not cancel.
Paulus
Postby Paulus » Thu Jul 09, 2015 10:37 am
Makes sense.
I am talking about a hotdog yes, with no onion.
Longer the better makes sense now for a material effect. I've read i should be able to go for roughly a 4" diameter hot dog bun.
Hopefully will get this done today or tomorrow.
I've embarked on a soundproofing journey with mass loading on panels with a foam layer which make me realise the drone is actually insanely loud
Paulus
Postby Paulus » Thu Jul 09, 2015 10:53 am
My worry around performance was turbo spool- just a nominal impact?
Postby NitroDann » Thu Jul 09, 2015 1:07 pm
NitroDann wrote:Fitntge largest body straight through perforated core muffler that you can possibly fit in a different length to the current one
or tune required.
Postby hks_kansei » Thu Jul 09, 2015 1:28 pm
I think the basics are that hotdogs/resonators/straight through exhausts don't add much, if any restriction to flow if they are sized correctly.
If you were putting in a more standard style of muffler, where the exhaust passes around multiple baffles, or passes through the muffler mutliple times, then it might be more a problem.
Paulus
Postby Paulus » Fri Jul 10, 2015 5:07 pm
Cool - so back from the exhaust shop and i can't pretty confidently say it has made zero difference.
Still got 3 different drones; idle, 2,800rpm and 3,500 rpm.
I haven't inspected the installation, but pretty safe to say the 'resonator' failed to perform it's purpose.
Next options? muffler?
speed
Postby speed » Fri Jul 10, 2015 6:18 pm
^ Paul, what is the diameter of your exhaust and what material. Ss or mild?
Also think you said straight thru muffler. How long?
Paulus
Postby Paulus » Fri Jul 10, 2015 7:52 pm
Here's what I got- sorry about terrible pics
I have a reasonable muffler on the back beneath the boot (what I wrote in the first post was wrong)
Rear of resonator
Cat into the 'new' resonator
Side on
Postby bruce » Fri Jul 10, 2015 8:01 pm
The idea is to fit the biggest resonator you can. Usually double that length.
Paulus
Postby Paulus » Fri Jul 10, 2015 8:08 pm
I don't think you could go longer as you'd hit the rear subframe.. I'll have to take a closer look.
I literally had to leave the car with them stating "fix the drone" before heading to my white collar job. Suspect all that was heard was "fit a resonator". The guy told me he had some long hotdogs yesterday. :/
Paulus
Postby Paulus » Fri Jul 10, 2015 8:12 pm
Looking at the first pic, it does look like you could get at least 50% more length.. Unless it's fouling somewhere. I'll have to take a closer look.
I hate this situation... I know that reasonably I'd have to pay the same again for a new install.. Where I'm concerned it won't do anything. Paid $140, which I thought was fairly reasonable
Postby NitroDann » Fri Jul 10, 2015 8:59 pm
Basically, your exhaust is of poor design.
I mean not just the components but their position and the shape and placement of the pipes also.
