Coil overs
- Learner Driver
Re: Coil overs
Thanks Magpie. My rear shockies are stuffed and I didn't want to wast money replacing them with oem ones. Mite have to revisit the budget
Re: Coil overs
As an alternative find something second hand to get the rear in a drivable condition whilst you look at options.
- Learner Driver
Re: Coil overs
Yes have had a wheel alignment and full suspension check all is good, thinking with going with yellow spread to start with. Going to give it a run a Lakeside on the 20th.
Re: Coil overs
Make sure you have a chat with the other drivers at Lakeside to get some feedback on what they are using. Don't forget there are some really fast drivers on OEM suspension.
