Emily's 04 VR SE
Roadrunner
coyotes after you
Re: Emily's 04 VR SE
Postby Roadrunner » Fri May 22, 2015 9:42 pm
emily_mx5 wrote:ARC TiTan gearknob :JDM:
Thanks 8)
MeepMeep
emily_mx5
Postby emily_mx5 » Tue Jun 16, 2015 5:43 pm
Little update :)
JDM Broadway Convex Mirror, clips over the standard one. Opens up field of view considerably. I love it.
Also replaced the gearbox oil with Redline lightweight shockproof, and both upper and lower rubber shiftboots (of course they were split) and the little nylon bush.
As always, feels like a new gearbox and shifts like butter. No more 6spd woes haha, doesn't require a short shifter thankfully.
On my quest to vent everything to atmosphere, I decided to delete the oem catch can set up. Firstly had to get the sump drain welded up.
I bought a “Cusco” catch can for cheap from ebay. Ricey peice of sh*t was empty lol.
Drilled a large hole the in the top, filled it with steel wool, so the oil vapours actually have a surface to condense on, and screwed a barb in for a breather filter.
Secured it with supplied brackets where the oem airbox used to be. Painted it satin black and finally installed my Carbing brace!
For the PCV to manifold vent, I fitted a small fuel filter inline to help catch some oil so the low octane oil vapours aren't fed into the engine at vacuum. Minor mod but I've seen it done on MiataTurbo, and every bit counts.
After being in for about a month there is some liquid oil pooled inside, so it is working!
Massive update coming :)
Apu
Postby Apu » Tue Jun 16, 2015 6:19 pm
Like the fuel filter idea! Going to copy that!
Postby bruce » Tue Jun 16, 2015 9:28 pm
Catch can won't work fitted upside down. If it gets any oil in it, the fitting will be under oil.
emily_mx5
Postby emily_mx5 » Wed Jun 17, 2015 1:14 pm
^True, but I check it every month and there has been no more than a teaspoon total in ~4 months.
I will be getting a proper one fabricated at some stage though.
lightyear
Infinity & Beyond
Vehicle: NA6 - Turbo
Postby lightyear » Wed Jun 17, 2015 1:37 pm
You won't get oil till you do some sustained high speed cornering. I know... :)
Ruffian147
Postby Ruffian147 » Thu Jun 18, 2015 12:30 am
You're oil catch can is the wrong way around. It's upside down, oil will go back in.
emily_mx5
Postby emily_mx5 » Thu Jun 18, 2015 10:03 am
^Yes this has been established, however the fitting is 1cm up from the bottom, there is no way it will fill up to the point of backing up the hose at the rate of 1tsp every few months. Engine is healthy and doesn't have blow by issues.
Postby hks_kansei » Thu Jun 18, 2015 12:56 pm
It will work fine.
worst case it will just act like a really tiny catch can (the 1cm bit)
The time it will take to even fill that would be ages if the blowby is anything like on my car, which has only a light mist and maybe 2 drops of oil in the breather pipes after 15 years.
Currently I just have a hose leading from the rocker cover to one of those ugly mini-pod things which i've hidden inside the guard since it looked like sh*t.
emily_mx5
Postby emily_mx5 » Sun Jun 21, 2015 3:09 pm
^exactly :)
I've flipped it today just to be safe, will upload a pic later.
Trackphotos
Postby Trackphotos » Sun Jun 21, 2015 4:57 pm
Did those 16x9s ever go on?
emily_mx5
Postby emily_mx5 » Fri Jul 03, 2015 5:58 pm
NitroDann SE upgrade kit
After very thoroughly servicing the car, including all fluids replaced with uprated synthetic options, new tyres, new brake pads, uprated cooling system etc etc I felt I had done enough supporting mods to start playing with power…
So began the rather daunting task of collecting the necessary parts.
Larger injectors: ID725s
Injectors are “universal”, however these come with beautifully machined alloy adapters to fit the fuel rail, and connectors to solder/crimp on to the wiring loom.
Larger intercooler: JJR Cooling pro unit
Intercooler install was straight foward, used the oem pipes with sections chopped off and rebeaded at the ends. Also used new 2” silicone joiners with Tbolt clamps.
BOV: Tial Q50
Hidden in the bumper behind the foglight, the oem undertray and wheel well liners completely hide this. Makes the greatest PSHHHHH noise.
Standalone ECU: Haltech Elite 1500
Behold. The most expensive part on the car haha.
Comes with an adapter loom, which required a few changes to work perfectly. Still in prototype stages, however I have been offered a completed sealed loom when it is ready.
WBO2: Haltech sensor + CAN controller
Requires constant 12V and ground, so I tapped underneath the fusebox for power and earthed underneath its bracket.
Very expensive, but i’m glad I went with the Haltech part, as it actually failed the first day of driving, threw a CEL and sent me into a panic attack haha. They remotely scanned the ecu, turned off the cel and told me it was fine to drive to them, where they replaced it instantly free of charge.
EBC: Haltech 3 way mac valve
I mounted this in the oem spot like most people, as the oem wires are easy to tap into and it just requires a simple bracket.
I had Dann fabricate a different throttle body intake pipe, as I now have the BOV on the intercooler pipe. It also needed to be a tighter radius to clear the stupid FM top radiator hose.
I also had Dann fabricate me a new intake, as I wasn't having the BOV or catch can recirculate into it anymore, and I wanted an enclosed filter. You know, because the car is so legal in every other way lol.
Just one barb for the boost controller, and a gradual taper to the 3” Works Engineering Carbon Fibre enclosed filter with a bellmouth. Filter is braced off the intercooler pipe. MAF delete because Haltech runs on an internal MAP sensor.
And no turbo car is complete without a full 3” exhaust…
So this was done too. Gorgeous welds and perfect fitment as usual.
Set up consists of turbo back 3” stainless steel, flex joint, bullet high flow ceramic race cat, NO RESONATOR, Magnaflow sports muffler, 3.5” rolled tip.
How does it sound? Astonishing. Completely unobtrusive when cruising around daily, no drone, not loud but audible. It has a beautiful note on idle, screams on harsh acceleration, and the best part? The burble crackle and pop on engine decell/overrun. Words cannot describe the rumble that carries on. It certainly does not sound like a little 1.8L lol. In fact, I had a red P plater kid in a Pulsar ask me “Does your Miata have a V8 in it?”. True story, its that good.
There are a quite a few people who can vouch for how amazing it is, shoots flames and everything. Phenomenal product and responsible for a massive power gain haha.
:mrgreen:
Roadrunner
coyotes after you
Postby Roadrunner » Fri Jul 03, 2015 6:42 pm
Mmmm Nitrodann welds 8)
Super jealous of your car
Got those wheels on yet? :P
MeepMeep
emily_mx5
Postby emily_mx5 » Fri Jul 03, 2015 10:13 pm
Wheels (well tyres actually) don't "fit".
They will, just not a direct bolt on right now.
speed
Postby speed » Sat Jul 04, 2015 12:07 pm
Wow. Most be awesome to have gotten to the power stuff. Car looks great and your standard of work is remarkable.
Next time I buy parts from you I'll be sure to bring some marshmallows to toast off your exhaust :)
Have two questions for you.
1. Has the tb elbow been beaded or was that not necessary?
2. Where and how did you run your WB wiring to get the unit into the cabin?
The plugs are massive and I'm thinking I either go thru the Trans tunnel or chop/de-pin the wires and run thru the hole in firewall with oem loom.
Thanks Again :)
Users browsing this forum: No registered users and 95 guests
