FYI-
You can get a new sump plug with an "o-ring" half way up the thread, that apparently creates a seal.
Super Cheap has em.
Oil Leak
Re: Oil Leak
MrNuts wrote:Quick update.
The oil leak is still there. Its leaking from the drain plug, not the oil filter.
I noticed that it only leaks if I take the car for a drive, which is almost every day.
Gonna order a new plug and new washers, then replace them after my exams. So in about 2-3 weeks.
The oil level is still around full, so hopefully the engine wont get damaged.
Oil thins as it heats, so the leak after driving would just be the oil getting thin enough to seep out. it's pretty normal for a leaky sump plug.
Engine won't get damaged unless you ignore it and let the oil drip out until it's low, since the difference between low and high on the dipstick is about 800ml, and the leak is presumably just a drip, you should be fine for a fair while.
Re: Oil Leak
ddgreasemeup wrote:FYI-
Super Cheap has em.
Re: Oil Leak
Super Cheap has em.
Yeap, saw some at repco a while ago. Might just grab those haha.
- Vehicle: Non MX-5
Re: Oil Leak
Then it should be amber, not brown when going in.MrNuts wrote:project.r.racing wrote:mineral oil
I used Valvoline 5W-30 synthetic oil.
