Lightyear's SE Replica Track/Road MX-5
beavis
Re: Lightyear track car. Version ? Lost count...
Postby beavis » Sat Jun 06, 2015 10:38 pm
lightyear
Infinity & Beyond
Vehicle: NA6 - Turbo
Re: Lightyear's SE Replica Track/Road MX-5
Postby lightyear » Sun Jun 07, 2015 8:35 am
Thanks for that.
Postby NitroDann » Sun Jun 07, 2015 11:22 am
lightyear wrote:I can't believe that tiny little turbo can make the car go so well. If you don't have a turbo, your really missing out.
I just think why haven't I always had a turbo MX5. And people that have man sized turbo MX5's, man, they must be insane to drive.
Yep. :lol:
davekmoore
Postby davekmoore » Sun Jun 07, 2015 2:55 pm
How do you change the subject title?
beavis
Postby beavis » Sun Jun 07, 2015 5:51 pm
A forum Moderator can do it.
lightyear
Infinity & Beyond
Postby lightyear » Wed Jun 10, 2015 12:05 am
I have repurposed the damaged spare bonnet. I figured the radiator will need all the help it can get. Marked some lines, made some cuts with the grinder, then bent up some alloy sides and riveted them in. And patched the hole from the naca duct.
image hosting 10mb limit
Postby Okibi » Wed Jun 10, 2015 2:08 am
Given you have pretty decent sized holes in the bonnet, I always wondered if there was much merit in trying to create a duct in the tiny space between the radiator and the engine (without v mounting) to push most of the air up through the vent. Like the WRC cars.
Someone with your skills could make a sexy carbon fibre option.
lightyear
Infinity & Beyond
Postby lightyear » Wed Jun 10, 2015 7:55 am
Will never work on this car. The radiator is pushed back 75mm. The radiator hose and bov and bits are all in the way. Would be nice. The c.f car will have something like that. Radiator will be in the boot space in that car for better ducting,
lightyear
Infinity & Beyond
Postby lightyear » Wed Jun 10, 2015 4:58 pm
Bit of black paint to finish it off.
beavis
Postby beavis » Thu Jun 11, 2015 2:08 pm
I hear the car is making an impressive 124.9kw and heaps of torque on the Dyno today.
lightyear
Infinity & Beyond
Postby lightyear » Thu Jun 11, 2015 2:30 pm
Give or take 60 kw's.
bartmanftw
Postby bartmanftw » Thu Jun 11, 2015 3:24 pm
I think it needs more :wink:
lightyear
Infinity & Beyond
Postby lightyear » Thu Jun 11, 2015 4:16 pm
124.9 keeps me in restricted open. It could however be making more depending on dyno.
Will see if I can come up with some video. There was a number of 181 on the screen at one stage. But we didn't do a power rn at the end, and didn't get a dyno sheet.
lightyear
Infinity & Beyond
Postby lightyear » Sun Jun 14, 2015 10:11 pm
The car performed well today at Broadford, nothing broke. ��
I could not fix the oversteer problem. Needs a wing maybe. The brakes overheated, but In the following sessions I braked a bit earlier and they stayed consistently average for the day.
Needs a catch can, as the oil stays in the head a bit too long from G forces. All things I knew would happen. Except the oversteer, thought that wouldn't be as bad.
Ended up with fastest time outright on the day, and broke the club record by about 2 seconds. But sadly I won't get the record because I didn't hand in my Motorsport application to the MX5 club.
It doesn't feel as fast on the track. Could be the rich mixtures it has now after fitting a new fuel filter. The one that was on the car when dynoed was probably the original that has done 211,000km's.
Over 2.0 class results.
post images
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Mon Jun 15, 2015 9:39 am
wow, a legit m3 csl hey?
i saw one of those on the road the other day.
Users browsing this forum: No registered users and 311 guests
