NB no start issue.
melv1n
NB no start issue.
Postby melv1n » Sun Jun 14, 2015 5:05 pm
Hi guys,
Trying to diagnose a crank no start issue with my 98 nb.
I read when the ignition is switched to on the engine light on the dash should light up to indicate the ecu has power.
Mine only lights up Seatbelt, Battery and Handbrake.
It's cranking fine but not catching, has fuel and spark ok. Fuses ok.
Pete
melv1n
Re: NB no start issue.
Postby melv1n » Sun Jun 14, 2015 6:53 pm
Interesting update.
I unplugged the fuel pump relay and then cranked it to see the difference......and it fired up for the first time in a few days.
It obviously died shortly there after but thats certainly interesting.
No idea what it means though. lol
oozmakappa
Postby oozmakappa » Sun Jun 14, 2015 11:02 pm
melv1n wrote:Interesting update.
could be your fuel pump's dead?
Postby manga_blue » Sun Jun 14, 2015 11:57 pm
Weird. The fuel pump is needed to supply pressure to the injectors. With the relay out there'd be zero fuel running through to the motor. Therefore to fire up there must have been fuel sitting in the inlet ports already. i.e. The motor was flooded. No idea how you can get a flooded motor with electronic injection though.
Can you repeat that? Try to start it with relay in, fuel it up, remove relay, start and run it until all fuel burnt? I don't know what it tells you but someone here might have seen it before.
RS2000
Postby RS2000 » Mon Jun 15, 2015 9:19 am
melv1n wrote:I read when the ignition is switched to on the engine light on the dash should light up to indicate the ecu has power.
I could be wrong, but I don't think NB1's had an engine light - only seatbelt, alt (battery), handbrake & airbag.
rascal
Postby rascal » Mon Jun 15, 2015 10:53 am
manga_blue wrote:Weird. The fuel pump is needed to supply pressure to the injectors. With the relay out there'd be zero fuel running through to the motor. Therefore to fire up there must have been fuel sitting in the inlet ports already. i.e. The motor was flooded. No idea how you can get a flooded motor with electronic injection though.
I actually had a similar scenario at Sandown a while back. Car wouldn't start and plugs were dripping wet with fuel.
Engine cranked over at almost normal speed, and plugs would show spark when sitting on engine cover.
Turned out to be loose battery cable lead, ( :oops: )which would give enough power for spark when no compression (ie plugs out) but wouldnt fire when plugs back in.
ECU provided fuel and triggered coils as per normal but obviously not enough juice to fire COPS and it just flooded engine.
Tightened battery cable and after a few cranks with WOT for fuel cut to disperse the extra fuel, car started no problems..
Postby hks_kansei » Mon Jun 15, 2015 10:58 am
I had similar to Rascal.
Over time the battery clamps stretch and lose their grip, my car would run fine then occationally just not start (mine would lose power fully though, no crank, no lights, nothing)
I just replaced the battery terminals.
Postby manga_blue » Mon Jun 15, 2015 11:48 am
So it seems that weak power supply to the coils is the cause. I'd check for:
- weak battery (maybe try starting it with jumper leads off a car with a good battery)
- loose battery terminals
- loose or corroded earth straps (front and rear of inlet manifold, behind dipstick and rear of PPF)
- dodgy MAIN relay
- damaged coil pack wiring connectors (the wires leading into the connectors are known to be prone to failure inside the insulation)
- old spark plugs or leads. Plugs are good for 20k, good leads last 100k, bad leads much less
- corrosion where the spark plug leads connect into the coils
melv1n
Postby melv1n » Mon Jun 15, 2015 1:41 pm
Thanks a lot guys.
I pulled the plugs this morning and they are all fueled up.
Replaced them and no change, battery terminals seem ok and tight, certainly providing good spark to the leads.
Went to repco to replace the ignition leads and he quoted me $210.
So i think i will ring around for them.
Really appreciate that list manga, especially the earth loccations.
Will run through the list tonight.
Pete
Postby hks_kansei » Mon Jun 15, 2015 2:01 pm
$210 is well above the normal price.
In saying that, MX5 leads seem to be stupidly priced compared to other cars anyway.
From memory Supercheap do Bosch leads for about $80
I have Magnecor leads on my car, they're about 15 years old, they're discoloured and have been oil soaked, but they still work. The only issue on them is that the clippy part on lead 1 has worn, so it no longer clicks onto the plug properly
melv1n
Postby melv1n » Mon Jun 15, 2015 2:08 pm
One other quick question.
The ngk ignition leads for a 98 nb, RC-MZN802, come in a pack of only 2 so obviously thats for a later twin coil nb.
Any know if na8 leads would work with no issues with an nb8a?
Cant get any Bosch local, might have to order.
Thanks again
Postby hks_kansei » Mon Jun 15, 2015 3:14 pm
NA8 leads work fine, as do NA6 leads.
Just make sure you attach them in the right order. I seem to remember the NA coils were mounted the opposite way around to the NB or something.
The leads are the same though, the leads on my car came directly from an NA6
melv1n
Postby melv1n » Mon Jun 15, 2015 4:32 pm
Damn...i pulled the fuel line off the fuel pump housing and the 2 o rings and the blue collar came out of the line as it pulled away, i.e stuck to the metal spout going to the pump one of the o rings was broken also.
Can i replace the seals inside or do i need to replace the entire line?
melv1n
Postby melv1n » Mon Jun 15, 2015 6:27 pm
Im talking the o rings and the spacer in this btw.
Looks like a much bigger job to replace the entire line.
melv1n
Postby melv1n » Mon Jun 15, 2015 8:09 pm
i will just order a replacement, not worth ahortcuts with fuel lines.
