Quick question please.
I understand from a good source that the MX5 SP Turbo uses the same springs and shocks as the standard NB8B.
Will these fit my 1999 NB8A without any modification? I would imagine that even in stock form the NB8B/SP springs and shocks would be stiffer than my stock NB8A setup.
I can get a complete set front & rear from a 50,000km SP Turbo for $200. Good value or waste of money?
Thanks, David
Mazda MX-5 SP Turbo 2002
- vscalais
Ask for forgiveness, not permission
Re: Mazda MX-5 SP Turbo 2002
I personally wouldn't bother.
From memory the SP gear was all just standard NB8B, which is pretty much the same as what you've got.
The SE had stiffer, slightly lower, springs.
- bigdog
- King of the kennel
Same as stock NB8B. Definitely don't bother. Spend your money on something better - SE Bilsteins, Tiens, Bilstein PSS9s or MCA etc .
- vscalais
Thanks Richard and everyone else. Will invest in your collective wisdom rather than waste my cash.
Much appreciated.
Much appreciated.
