He said there was a noise in the back wheel
No, your eyes don't deceive you. That bit of metal in my hand was once a rear disc rotor, now neatly peeled off its hat. Some evidence of a rock having been embedded on the leading edge of the inside pad. Amazingly no other damage except a thick coating of rusted iron powder on the rim.
Re: He said there was a noise in the back wheel
Now that's a true full floating rotor...
VW going by the stupid wheel bolts instead of studs?
At least this isn't as bad as the ones that wear past the rotor face and just have the inner fins left.
This one could use the excuse that it still looked normal(ish) behind the wheel.
Mercedes. I loathe and detest those wheel bolts.hks_kansei wrote:VW going by the stupid wheel bolts instead of studs?
This has gone way, way beyond that. It's a solid rear rotor that was 8mm thick new and is now worn down to about 0.5mm thick before being sliced or ripped off the hat.hks_kansei wrote:At least this isn't as bad as the ones that wear past the rotor face and just have the inner fins left.
- JBT
manga_blue wrote:I loathe and detest those wheel bolts.
A BMW thing too...PIA
- Vehicle: Non MX-5
This has gone way, way beyond that. It's a solid rear rotor that was 8mm thick new and is now worn down to about 0.5mm thick before being sliced or ripped off the hat.[/quote]So the owner just ignored the squeeling the rock was causing for 10s of 1000s of kilometers until bang?manga_blue wrote:This one could use the excuse that it still looked normal(ish) behind the wheel.
Yeah, pretty much.
Remember to take the rocks out, kiddies.
Users browsing this forum: No registered users and 152 guests
