CoffeeBoss
suntory
Postby CoffeeBoss » Wed May 13, 2015 5:24 pm
Lokiel wrote:Normally I REALLY hate them but for your NT trip, a car bra would be a good option.
This. In my experience, you may need to ensure there are no points of contact with the carbra that may rub against your paint (the one I have for the NC has plastic clips which I cover with leccy tape to avoid abrasion). Worthwhile though, if only to avoid having to scrub of all the dead bugs at the end of your trip!
Postby bruce » Wed May 13, 2015 9:58 pm
bruce wrote:Spray on car bra? Plastidip and another brand do peelable plastic.
billybunter
Postby billybunter » Wed May 13, 2015 10:40 pm
I may go that way too. I just plast-dipped these frog arms today
billybunter
Postby billybunter » Thu May 14, 2015 4:35 pm
used a door stopper to hold the door in place while I undid the door bolts
and one side almost completed
Postby Lokiel » Thu May 14, 2015 5:58 pm
Glad you painted them white, they would have been extremely noticeable in green against your white car.
Tip: Use your scissor jack to help align the doors correctly and do take the time to do it properly - you'll hate yourself otherwise if they don't shut nicely.
Also, you should use washers on those bolts - get some larger ones from Bunnings because mine weren't wide enough.
billybunter
Postby billybunter » Fri May 15, 2015 2:23 pm
as always good advise-will look into it.
billybunter
Postby billybunter » Sun May 17, 2015 4:30 pm
today I hit the intercooler with a bit of stealth paint :lol: just in case I run into the ass of a Porsche on that outback stretch :twisted:
billybunter
Postby billybunter » Fri May 22, 2015 5:09 pm
new lower boot shifter seal arrived today
old one was pretty well done!
Roadrunner
coyotes after you
Postby Roadrunner » Fri May 22, 2015 9:38 pm
Is the bushing still in the turret? I noticed it's not on clipped on the end of the stick in the second photo
MeepMeep
billybunter
Postby billybunter » Sat May 23, 2015 12:48 am
good observation! :wink: I have just replaced it with the delrin shifter tip bushing from miata roadster which so far I am pretty happy with the swap.
Roadrunner
coyotes after you
Postby Roadrunner » Sat May 23, 2015 9:18 am
They make a noticeable (in a good way) difference to the shift!
Such a crappy original piece from Mazda. My factory one kept falling off, so put a large washer in the bottom of the turret to hold it in till I upgraded to a short shifter
MeepMeep
billybunter
Postby billybunter » Sat May 23, 2015 5:05 pm
new upper shift seal on - original was split too
console back in
finally after the frog brace install and the door adjustment - one guard back on today
billybunter
Postby billybunter » Sun May 24, 2015 5:52 pm
this stuff arrived earlier in the week from garage star in the usa so I thought while I was friggin about with the frog arm install these might as well go on too.
open wiper box locality
following the install
while at the front I decided to redo the inner front rims too.
after that the radiator cowling
job completed. not sure if it will help but it looks a lot cleaner
Roadrunner
coyotes after you
Postby Roadrunner » Sun May 24, 2015 9:58 pm
That engine bay looks far too clean. A drive through the NT should sort that right out :mrgreen:
MeepMeep
billybunter
Postby billybunter » Sun May 24, 2015 11:34 pm
true! ...what I have plan for it is a pretty long run plus a fair bit of dirt so I guess will either drive it back or scrap it... :lol:
