Fuel Cap Problem
Hot Rodders
Fuel Cap Problem
Postby Hot Rodders » Sat May 23, 2015 10:54 am
I'm having problems with the fuel cap not opening. I've tried looking up a previous topic on the matter but can't seem to find. Can anyone shed some light on this problem?
Cheers!
HR
Evo, Its not a Dirty Word! Good As Gold.
President Bendigo Gliding Club
www.bendigogliding.org.au
Garry
Re: Fuel Cap Problem
Postby Garry » Sat May 23, 2015 11:32 pm
As in you pull on the lever and the nothing happens or you pull on the lever and the plunger moves but the lid doesn't open?
If it's the first check that the cable is attached to the lever in the console and the plunger behind the boot lining. Also check that the cable is adjusted correctly.
If it's the second then check that the opening spring is still attached.
I'm not sure how the stock lid works but my SP has a chrome lid and the spring sometimes gets gummed up so doesn't push the lid up.
Hot Rodders
Postby Hot Rodders » Mon May 25, 2015 9:34 pm
Thanks Garry. The problem is the second and it seems to be something with the little black rubber groments.
I too have a chrome cap.
Cheers!
Rod
Garry
Postby Garry » Mon May 25, 2015 9:40 pm
There was a revision of the grommets on the early caps. They redesigned them so they didn't stick. I'd still be having a look at the release spring. It's up near the hinge. I had to clean and lube mine a few months ago because it was sticking again.
vscalais
Postby vscalais » Thu May 28, 2015 6:15 pm
Had the same problem. Just backed off the release spring slightly so that it didn't engage on the black knob so far. Hope this helps.
Ask for forgiveness, not permission
Hot Rodders
Postby Hot Rodders » Fri May 29, 2015 12:02 am
Thanks guys, I'll have a look see at the weekend.
Cheers!
8) HR
