Re: NC 20BPP Time Attack / Track Car - Build Thread
HP is much closer to what I had originally expected now.
- orx626
- Vehicle: NC - Rotary
Some good news....the production of the outstanding composite components is underway.
The aim is to have it all completed and installed by mid-July. This will give us 3 months to test and set the suspension. It's less than 150 days until WTAC 2015!
A bit of due diligence on the used HKS sequential averted a disaster after crack testing highlighted the imminent failure of a dog ring. So this has delayed the installation for a few weeks.
However, it hasn't prevented the necessary modifications required to allow its fitment. As the box is essentially a modified FD3S RX-7 gearbox we were able to use another box to undertake the necessary modifications.
A little weight reduction was a nice bonus.
A new PPF was constructed from pieces of RX-8 and RX-7 items. The tailshaft is unmodified. The other bonus is that the gearboxes are interchangeable....just need to use the appropriate PPF and clutch slave cylinder.
Seeing as the rear muffled section of exhaust has been essentially torched and the mufflers appearing to be ineffective I thought that we might as well save some weight.
When we fired up her up the extra dB proved otherwise!
So the 'torched' rear muffled section of exhaust went straight back on.
I'm looking forward to getting some more seat time over the next week.
- zero00
Hopefully see you at QR Monday Danny
Roger D-SUNSHINE COAST
- orx626
zero00 wrote:Hopefully see you at QR Monday Danny
- timk
Hi Danny,
Is that a thermistor in the diff housing?
Is the shifter in the same position on the FD gearbox out of interest?
I will post the video of it overtaking me so you get to hear it from the outside perspective...
- Vehicle: Non MX-5
Magpie wrote:As promised
Apologise to OP for being off topic, but what video/data system do you use? Very cool
Racelogic Vbox Lite with a micro input module (RPM, brake/TPS sensors plus 2 other 5 volt sensors if required) and OLED display (lap timing etc).
- beavis
- Vehicle: NB8B - Turbo
Was trying to work out what all the grind marks were from in this pic.
But then I see you mentioned 'weight saving' so I assume they are a result of the factory gusseting you removed?
- 16bit
14 days to go, hows it coming along?
- Dweezle
I have not seen any entry info for this car???
A huge Shame if you do not make it
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- Regie
- Vehicle: NC - V8
message from Danny.
Due to work commitments he won't be able to make WTAC this year
- 16bit
didn't think so. he was not entered on the WTAC website.
oh well, the track and competition are not going anywhere.
at least he can have a longer time to test with the new aero!
Bump
Any updates?
