Best starting point for track work
Re: Best starting point for track work
Postby NitroDann » Thu May 21, 2015 2:34 pm
Calling chrons_rotary
beavis
Postby beavis » Thu May 21, 2015 3:10 pm
kazama wrote:
Black_Penguin wrote:Most powerful stock motor, biggest standard brakes, most standard bracing, 6 speed standard.
Pretty much most parts are interchangeable between NA/NB.
From memory the NB's had slightly revised/improved suspension geometry as well
yes, they are wider
chrons_rotary
Postby chrons_rotary » Thu May 21, 2015 3:55 pm
If you are in the hunter and interested in doing some hillclimbs, you should join the MG Car Club of Newcastle and come along to some of their hillclimb days at Ringwood Hillclimb 10km north of Raymond Terrace.
In regards to class and door to door, probably best of starting out in 2f and getting use to it first.
In any case, start with upgrading/buying all the safety gear, as crashes happen regardless of what class/discipline you run.
With the NA/NB debate, the NB is probably the better starting point for racing, but NAs are a bit cheaper and imho have more character. :)
Ken.
Users browsing this forum: ak_perth and 11 guests
