SE lifter noise
track_addict
Re: SE lifter noise
Postby track_addict » Tue May 19, 2015 8:12 pm
Here's a video of the noise. Pretty nasty injector if thats what it is haha. Car runs fine other than the noise. After watching it again, it sounds expensive, very expensive.
https://www.youtube.com/watch?v=-SHYxOTc0O8
89' Roadster - Sold
'04 SE - Sunlight Silver.
Re: SE lifter noise
Postby manga_blue » Tue May 19, 2015 10:15 pm
Piston tapping the head.
track_addict
Re: SE lifter noise
Postby track_addict » Tue May 19, 2015 10:56 pm
Whats the most common cause of that? Stretched valve? Or rod damage? My mechanic did suggest this as a possibility but not possible causes.
89' Roadster - Sold
Re: SE lifter noise
Postby manga_blue » Wed May 20, 2015 1:18 am
Big end or small end bearing failure, stretched/broken big end bolt, bent piston pin, cracked piston, etc. The risks of dyno tuning. Nothing you'd want to find. Are you certain it's inside the engine and not just some ancilliary?
Borrow the bore scope again and check your piston tops again for signs of touching the head. Or else get a mechanic with plenty of experience with bad noises. Run a compression test yet?
track_addict
Re: SE lifter noise
Postby track_addict » Wed May 20, 2015 7:48 am
The tuners did a bit of diagnosing and they had all the accessory belts off and they said the noise didn't change. My plans for this weekend are to compression and leak down test it, then take the timing belt (and accessory belts in the process) off and have a look around that area as well as run the car and use a stethoscope to have a good listen. Will basically just keep trying to eliminate possibilities until I just have to take the whole bloody thing out to find out whats wrong.
89' Roadster - Sold
Re: SE lifter noise
Postby manga_blue » Wed May 20, 2015 1:02 pm
You need to be careful about running up diagnosis costs. It's fine if you do it yourself but costly if you're paying.
I hate to be pessimistic but we had an NB8B engine sounding like that at Wakefield earlier in the year. Oil pump failure --> spun big end bearing, destroyed main bearing, terminally scored piston and bore, cam bearing damage --> no salvageable parts. Remember that you can get a decent NB8B motor for around $1,500. In this case the cost of stripping down a pile of junk was as much as a new motor. :cry:
[vultures circling] Dibs on your inlet maniold and valve gear. :D [vultures circling/]
track_addict
Re: SE lifter noise
Postby track_addict » Wed May 20, 2015 1:46 pm
I will be doing the work on it from now on. They only did some stuff initally to see if it was an issue that oculd be fixed then and there. Car has been home for a week now. I'm expecting it to be terminal, so no amount of pessimism will phase me. There are some markings on the bores but not from something gouging into it. Will post pictures tonight.
89' Roadster - Sold
SlugRacer
Re: SE lifter noise
Postby SlugRacer » Wed May 20, 2015 5:00 pm
My SE bent a rod on the dyno when the clutch decided to let go. No damage to the bearings, pistons or bore but piston was hitting on oil squirter which got bent. Rods and clutch were replaced and oil squirter bent back and all was good
Re: SE lifter noise
Postby NitroDann » Wed May 20, 2015 5:10 pm
If it were due to the clutch it would be an over rev and that almost never ever ever bends rods. Even if it was an over rev, the operator should have had a rev limiter set. What a noob.
track_addict
Re: SE lifter noise
Postby track_addict » Wed May 20, 2015 7:16 pm
Slugracer, it wasn't a full rebuild then? Can you give more detail at all? Trying to get an idea of how much wallet upset I'm in for.
89' Roadster - Sold
zossy1
Re: SE lifter noise
Postby zossy1 » Wed May 20, 2015 8:16 pm
...and i'll happily take the bottom end, as long as the block is not cracked... might even take the head too if the price is right (minus valve gear) ;)
manga_blue wrote:You need to be careful about running up diagnosis costs. It's fine if you do it yourself but costly if you're paying.
Re: SE lifter noise
Postby manga_blue » Wed May 20, 2015 9:33 pm
Sometimes there are no morals on this site. :roll:
track_addict
Re: SE lifter noise
Postby track_addict » Wed May 20, 2015 9:59 pm
Yeah um, if its terminal I'll be using what I have now for the rebuild. I'd say I'm sorry but, well, I'm not haha. Vultures be gone!
89' Roadster - Sold
SlugRacer
Re: SE lifter noise
Postby SlugRacer » Wed May 20, 2015 10:55 pm
Sorry I don't really have any more info. The tuner/mechanics replaced the rods for free, I paid for a new clutch. They now make customers sign a waiver before their cars go on the dyno. I guess you won't know the extent of the damage or what's damaged until you pull the engine apart
TrackAttack
Re: SE lifter noise
Postby TrackAttack » Thu May 21, 2015 5:57 pm
If you isolate cylinders (remove leads) you can shut down combustion on a cylinder. It helps to diagnose big end knock. I have personally heard big end knock that sounded like lifter noise/VCT knock
Users browsing this forum: Bing [Bot] and 3 guests
