Exocet Build 001
Moderators: timk, Stu, -alex, zombie
Re: Exocet Build 001
Not spending much time on this forum is a business decision that he has made. It may or may not be a mistake but its a decision that has been made.
- Vehicle: Non MX-5
Thanks for the info Dann. I'm not fussed where the info comes from. Just the that info dried up but no direction on where to follow on from there.
- Learner Driver
project.r.racing wrote:Thanks for the info Dann. I'm not fussed where the info comes from. Just the that info dried up but no direction on where to follow on from there.
Hi project.R
There are exocet agents in a few states now.
Depending on where you are based there is likely someone local to talk to about it. Matt and Dann are pretty flat out with the build of four more at the moment and these have had slight alterations from exo-001 so that they suit Aussie ADRs.
Shoot me an email if you are Adelaide based and you can look over my build once I get the chassis in a couple of weeks (evan@exocet.com.au) or I can update you with the build progression.
Evan
Return to “Engine swaps, Exocet, Locost & MX-5 kit cars”
