Sounds OK to me in theory but I'm no expert.
Thank you all
NitroDann wrote:It depends if the compressor efficiency significantly changed at different pressure ratio vs flow's.
Ie, you will need to swap the 7 psi pulley on and check the tune with a wideband, and check the plugs for knock to be sure. but why would you want to swap to a smaller pulley?
