How To Test B577 Fuel Pump Relay
Technical Guides primarily to do with the NA series
myredmx5
Postby myredmx5 » Tue Apr 14, 2015 12:46 pm
Can anyone advise me on how to test this relay?
Re: How To Test B577 Fuel Pump Relay
Postby 93_Clubman » Mon Apr 20, 2015 2:23 pm
From Rod's Enthusiast Shop Manual for Miata 1.8 Litre: 'Fuel pump relay checking. When batter voltage is applied to terminal A, and terminal B is grounded, there should be continuity between terminals C and E.'
Using your recent pic from another thread (which I've rotated 180 degrees & attached here), terminal B is top left, term A is bottom left, term C is bottom middle, & term E is bottom right.
myredmx5
Postby myredmx5 » Wed Apr 29, 2015 1:18 pm
Thanks for your helpful input 93_Clubman
Return to “NA [1989 - 1997]”
