Shifter and turret lube
- davekmoore
Should the shifter and the turret in an SE 6 speed have any kind of lube/grease etc on any of the parts?
Re: Shifter and turret lube
i just put a smear of synthetic grease over everything(kluber grease)when i replaced bush and boots.
i think whatever lube you put in the shifter area makes it way into your gearbox so i wouldn't be putting too much on.
its not like there is anything moving fast or underload in there...depending on your gearshanges
i could be wrong tho i never looked it up.
Prety sure the 6 speed is lubed from the main part of the box, but 5 speed definitely needs lube in the turret
greenltd wrote:Prety sure the 6 speed is lubed from the main part of the box, but 5 speed definitely needs lube in the turret
oil is not circulated through the turret on a 6 speed.
there is no metal to metal contact so just a bit of grease smeared on when assembling is ok.
- davekmoore
That white lithium grease ok?
- Roadrunner
- coyotes after you
davekmoore wrote:That white lithium grease ok?
Should be all good, but I used black all purpose lithium grease.
Seemed to be a bit thicker.
MeepMeep
- Roadrunner
- coyotes after you
I should clarify that that is just on moving parts in the turret (gear lever pivot etc), not in the actual gearbox ;)
MeepMeep
Users browsing this forum: No registered users and 26 guests
