Just out of curosity I was wondering what the standard rated kW at the rear wheels was for a 1.8 NB8A.
Like to compare what I've picked up.
Thanks
rascal wrote:From the Dyno days that the Vic club has run, the average for a stock standard NB8A is around 72rwkw.
Vat wrote:30% is pretty normal for rear drive - gearbox and a diff which includes a 90% change in direction. That's before allowing for engine and drive line aging, plus dyno differences...
pcmx5 wrote:3 years of dyno results on the same Dyno Dynamics set up for the Vic MX5 club showed an average 30-33% drive train loss.It also showed that NA6A's had a better ratio of loss than than NA8A's or NA8B's so Mazda may have had a bit of a "fiddle factor" in their measurements as evidenced by their need to replace cars/compensate owners under US consumer law when their claim of 113KW for NA8B.s was found to be false.
Peter.
DarrylA wrote:Hi guys
Thanks
