Hi Everyone,
On the drivers side, if you pull down the sun visor there are two bolts on a metal plate. the water appears to be getting in around that metal plate. Anyone else come across this?
ND leaking roof (soft top)
Re: ND leaking roof (soft top)
you have contacts in high places?
no one else will have the ND, let alone one with a leaking roof.
seriously tho i imagine the drivers side roof latch may need adjusting to pull the roof down harder on the rubber seal.
or the screws are loose on the latch hardware .
water probably gets in there and runs down to the plate where you see the drips.
sit inside and have someone hose the area from outside then it would be easier to see where the water gets in
look at the topic a few lines down.
Yeah wish full thinking should be NC
