Bullet superchargers
ben wilson
Re: Bullet superchargers
Postby ben wilson » Thu Mar 19, 2015 7:02 pm
A thought came to me randomly last night, they haven't fitted an inlet restrictor have they?
That would limit top end boost while giving a big kick in the mid range torque.
Novice1
Postby Novice1 » Thu Mar 19, 2015 7:58 pm
ben wilson wrote:A thought came to me randomly last night, they haven't fitted an inlet restrictor have they?
It is very torquey over 300 NM.
Hoping to start some tuning next week, so will see how it goes.
Novice1
Postby NitroDann » Thu Mar 19, 2015 8:16 pm
300nm measured where, even at the crank that's really not a lot?
Novice1
Postby Novice1 » Fri Mar 20, 2015 9:05 am
NitroDann wrote:300nm measured where, even at the crank that's really not a lot?
Dyno chart is at tuners garage, but from memory 320 plus ATW.
Standard NC around 188-190 NM.
Novice1
Postby hks_kansei » Fri Mar 20, 2015 9:18 am
I always thought that wheel torque on a dyno should measure quite high? (somehting about gearing or whatever)
When I dyno'd my old car, a Ford Mondeo, the chart showed wheel torque as something like 400nm
from memory the factory quoted engine torque was 140nm or something.
Dan
Postby Dan » Fri Mar 20, 2015 9:35 am
Maybe you are comparing nm to lb-ft?
Postby hks_kansei » Fri Mar 20, 2015 10:28 am
Dan wrote:Maybe you are comparing nm to lb-ft?
nope, all metric.
gear ratios, diff, ratio, and tyre size all add to magnify the torque.
WHeel dynos usually use 4th, which on most cars is close to 1:1 ratio.
Then the diff ratio, which on an NB is anywhere from 4.1:1 to 3.6:1
Then whatever sized wheel/tyre combo.
Postby NitroDann » Fri Mar 20, 2015 12:27 pm
Yeah as kansei said.
A stock na6 dynos at over 1000NM in 1st gear.
Novice1
Postby Novice1 » Fri Mar 20, 2015 4:50 pm
320 NM plus was fourth gear from memory.
Novice1
Postby hks_kansei » Fri Mar 20, 2015 5:03 pm
Still sounds really low, unless it's a corrected value?
as I said, my Mondeo Dyno'd around 400 (uncorrected)
I would hope that a stock NC would outdo that, let alone a supercharged one!
ben wilson
Postby ben wilson » Fri Mar 20, 2015 5:48 pm
It originally had 200NM, now it has 325NM.
The actual numbers don't matter, just the difference.
A 60% improvement in torque sounds about right for 7lbs, but a 14% increase in peak power makes me think that there is something wrong here...
Novice1 - Does it hit 7lbs before redline?
Postby Regie » Fri Apr 10, 2015 5:23 pm
any updates?
Novice1
Postby Novice1 » Fri Apr 10, 2015 6:45 pm
No updates Regie. Unless I can find Ecutek tuner I think I am stuck with what I,ve got.
Novice1
Postby Regie » Sat Apr 11, 2015 8:38 pm
So your mechanic "the best tuner in QLD" couldn't do anything for you?
You might have to head overseas for a good tune. Mike from Moto-east, all I've herd is praise from what he produces
http://www.moto-east.com/store/mazda/20 ... ducts.html
timk
Postby timk » Sat Apr 11, 2015 9:08 pm
Ron I'm pretty sure Lachlan from ChipTorque can do EcuTeK, he did a great job on my NB.
