newbie looking for help with an na6
Forster
Postby Forster » Thu Mar 19, 2015 10:32 am
Hi all,
Sorry to come in looking for help of the bat.
I recently did the head on my wife's pride and joy which she has had for 15 years and everything thing seemed to go well but on trying to start the car it runs (bairly) chugs and won't rev at all
I thinks I've gone through every post looking for a solution and covered all possible options but the no avail.
Any help would be greatly appreciated
Re: newbie looking for help with an na6
Postby NitroDann » Thu Mar 19, 2015 10:50 am
What have you tried?
Forster
Postby Forster » Thu Mar 19, 2015 12:18 pm
So far checked and rechecked timing, spark, had injectors checked, new fuel pump and the afm appears to be working.
Not sure where to go from there
Forster
Postby Forster » Thu Mar 19, 2015 12:20 pm
Also went over electrical connections checked cam sprockets and vacuum lines everything appears to be connected correctly, im at a loss
noobee
Postby noobee » Thu Mar 19, 2015 12:21 pm
also put in your location.someone close by may be able to help.cam timing?
Mick
Forster
Postby Forster » Thu Mar 19, 2015 12:40 pm
Thanks NooBee done
Postby bruce » Thu Mar 19, 2015 3:36 pm
Spark plug leads.
Forster
Postby Forster » Thu Mar 19, 2015 3:56 pm
Not.the.leads checked.the.plugs for.spark with the.leads
speed
Postby speed » Thu Mar 19, 2015 5:57 pm
Just wondering, is it possible to put the CAS in 180 degrees out or will it work either way?
Postby bruce » Thu Mar 19, 2015 6:47 pm
Spark plug leads.
Spark may not b strong enough or inconsistent.
ben wilson
Postby ben wilson » Thu Mar 19, 2015 7:12 pm
Have another look at the cam timing, a lot of people manage to muck it up.
Forster
Postby Forster » Thu Mar 19, 2015 9:59 pm
Ive checked and rechecked cam and belt timing all eceactly how it shoukd be
cas can only go on way
Forster
Postby Forster » Thu Mar 19, 2015 10:02 pm
Over the weekend ill pist a video on the car chugging along, it wouldnt run at all if the cams were wrong would it
also rained the tank used new fuel replaced the pump blown out the fuel lines
Postby manga_blue » Thu Mar 19, 2015 10:15 pm
Did you fill the HLAs with oil before you re-installed them? If you did then they're probably overfilled and as a result some of the valves aren't closing. Sitting under pressure in the engine lets the HLAs slowly bleed out the oil and return to normal working length. Leave it overnight and try again tomorrow.
Postby Mr Morlock » Thu Mar 19, 2015 10:20 pm
have you checked the compression. . Are the valve clearances correct. Ps just noticed mangas post and he will recall that a member had a prob on a rebuilt head because the valves were not seating and the guy had to reset the clearances after buying new shims- it's a thought.
