Broken dipstick handle
Silvia
Postby Silvia » Sat Mar 14, 2015 10:25 am
It broke off in the yellow plastic part just above the rubber seal ring . What is usually done when this happens? Is it a common Mazda one or do you send away to a MX5 specialist? thanks
Silver Nomad
2002 NB8C
Re: Broken dipstick handle
Postby NitroDann » Sat Mar 14, 2015 11:17 am
I commonly see a small hole drilled in the plastic and a keyring fitted.
sailaholic
Postby sailaholic » Sat Mar 14, 2015 11:50 am
Definitely a mx5 specialist. most Mazda dipsticks of that era look the same but have different markings dependent on which engine they were fitted to and FWD vs RWD. Incorrect dipstick could cause terminal engine failure!
beavis
Postby beavis » Sat Mar 14, 2015 12:05 pm
its just a dipstick. if its still filling the hole, leave it.
Postby Okibi » Sat Mar 14, 2015 12:22 pm
Get a small toy, drill a hole in the bottom and glue it on.
The American
Postby The American » Sat Mar 14, 2015 12:45 pm
You can repair this with a specialist HPDE glue. Don't bother using any other 'super' glue.
Make sure the glue specifically states that is works with HPDE.
Silvia
Postby Silvia » Sat Mar 14, 2015 12:51 pm
Thanks guys. Sailaholic....the metal part is ok just the plastic handle broke. I noticed when trying super glue that there are fractures all along it, so I doubt the glue solutions will work for long. If it breaks again I'm inclined to go the fingernails method of grabbing it where it protudes out of the tube. Only 87k kilometers too. :(
Silver Nomad
2002 NB8C
Postby manga_blue » Sat Mar 14, 2015 2:20 pm
Youtube plastic welding or HPDE welding.
Nevyn72
Postby Nevyn72 » Sat Mar 14, 2015 3:57 pm
Postby Mr Morlock » Sat Mar 14, 2015 4:33 pm
Kilometres has nothing to do with its failure imo it is more likely age. Plastics do degrade and it may well be a common item to fail. American is probably right as standard super glues simply don't work on some materials. If the handle which you put your finger thru to withdraw the dipstick is 2 part then in theory any extension will make it easy to remove. Maybe a rubber fitting is a possibility. The UK site seems to show a grossly overpriced part which gives a general idea of the shape you want.
Vat
Postby Vat » Sat Mar 14, 2015 5:51 pm
Did this myself last year - Automotive Plus (site sponsor in Qld) carry them for a reasonable price.
'98 Evo Gold NB8A
Nevyn72
Postby Nevyn72 » Sat Mar 14, 2015 10:43 pm
Mr Morlock wrote:The UK site seems to show a grossly overpriced part which gives a general idea of the shape you want.
Overpriced? Maybe but it's a specialised chrome piece and it's shiny! :mrgreen:
Postby manga_blue » Sun Mar 15, 2015 12:11 pm
I must admit that after 8 years of having a broken one I lashed out a few weeks ago and ordered a new one, along with a whole lot of other bits, from Amayama. I think this is the first non-performance improving part I've bought since 2007.
Amayama Trading wrote:Mazda BPE810450 GAUGE, OIL LEVEL - 11.95 USD, 1 items
Note: this is for an early NA8, you really do need to get the right one for your model.
mattyredlocks
Postby mattyredlocks » Sun Mar 15, 2015 1:49 pm
Mine was snapped off before I bought it - took my a year of ownership before I knew there was meant to be more on the handle.
Does it matter? Still enough left to plug the hole and grab onto, right?
Because reasons.
MattyRedlocks' MX-5: Moxxi the NB (Currently running, and properly for once!)
project.r.racing
Postby project.r.racing » Sun Mar 15, 2015 6:51 pm
It is a pretty easy fix for $12.00.
Users browsing this forum: No registered users and 50 guests
