hi there
I have a nb8b with a gt2560 on a low mount manifold by suli from pure fabrications
I am having issues fitting it
the intake to the turbo is just touching the coolant hose on the side of the block
What have people done to get a bit more clearance?
Sent from my SM-N910G using Tapatalk
Turbo fitment nb8b
Re: Turbo fitment nb8b
Was thinking a 30mm right angle then alloy pipe to join to stock coolant hose
Not sure if it will work
If its not going to chafe (no relative movement between the two parts) I wouldnt worry too much about the cold side. Turn the clip so it cant rub on anything. Most worries should be about the hot side.
jp 92na6, Clubby with a Turbo NA8.
Forget it its fine
Users browsing this forum: No registered users and 167 guests
