Wazman's NB8a
Re: Wazman's NB8a
Postby bruce » Fri Mar 06, 2015 7:44 pm
Good to see you're still kickin around.
lightyear
Infinity & Beyond
Vehicle: NA6 - Turbo
Re: Wazman's NB8a
Postby lightyear » Fri Mar 06, 2015 9:51 pm
You need some clear on that hardtop. Once it gets bashed up enough, you might need to do an overhaul.
Tube frame chassis with fibreglass panels.
wazman
Re: Wazman's NB8a
Postby wazman » Mon May 04, 2015 10:47 pm
Had a bit of bad luck/ too much limiter bashing+16 psi on standard bottom end.....
all the bits of metal on the edge of the guard are ment to be IN the motor :roll: You can see the bit closest to the head light is part of a rod :lol:
ilovedrift.com
wazman
Re: Wazman's NB8a
Postby wazman » Mon May 04, 2015 10:57 pm
From a previous event, Drift challenge Australia. I just like it because i can barely see where im going 8)
Look at my rear tyre.......popped and rolled off the rim..... NEVER LIFT ! (lucky they are just crappy rotor grids)
ilovedrift.com
