Door Rattle fix??
simie2014
Door Rattle fix??
Postby simie2014 » Fri Mar 06, 2015 11:54 am
Hi folks. Seems I'm always on here for advice. My 2000 NBa doors are rattling over bumps. I've moved the D shaped clamps (if that's what they are called?) further inward but they don't seem to move any further inward than they already are...and still doors rattle?? I'm thinking that the door rubber have shrunk over time (15yrs) I thought perhaps if I bulked out or pushed out the rubbers by placing a thin door felt behind the rubbers may do the trick by pushing the rubbers out more thereby fixing the doors harder to the body stopping the rattle but that doesn't seem to have worked? I'm sure this problem is not unique to my car so any ideas for a fix that has worked for forum members. Cheers. Simie
Re: Door Rattle fix??
Postby bruce » Fri Mar 06, 2015 1:07 pm
It could be anything.
Roadrunner
coyotes after you
Postby Roadrunner » Fri Mar 06, 2015 2:43 pm
Is it the whole door itself rattling/moving or is it a rattle sound coming from the door?
I have a rattle in the door when I turn right hard. Theres plenty inside the door cavity that can be rattling.
The big foam block, lock mechanisms, window glass, window runners, speakers or cabling etc etc
You just need to pull the door down and start looking.
I've been putting it off as im still having reoccurring nightmares dealing with the black sticky weather-seal crap last time I was in there
MeepMeep
simie2014
Postby simie2014 » Fri Mar 06, 2015 3:28 pm
Thanks for that. I'll pull the liner off again and have a real good look. Don't once and had a cursury look. Thanks.
AndrewM
Vehicle: ND - Supercharged
Postby AndrewM » Fri Mar 06, 2015 4:09 pm
My rattle turned out to be an ill fitted battery in the boot..tightened up the battery bracket and no sounds at all - r u sure its your door?
1997 NA8 BRG / Tan LE - AMX-597 - SOLD IN 2002
2000 NB8A Twilight Blue - AMX-518 - SOLD IN 2015
simie2014
Postby simie2014 » Fri Mar 06, 2015 6:55 pm
Yea can't be sure if its in the door that rattles. Sounds like it. Yea saw that black gunky stuff securing the plastic cover on the door. Bit scared of that too. Probably only way to check out the interior of the door is by pulling that off. Dont think its my battery and anyway the passenger door makes a noise too. When I am resting my arm on the door when driving and hit a bigger bump I think I can feel the door shake and seemingly move. Didn't really notice noise from doors until my mate adjusted the doors to make them flush with the outside of the car. Anyway, will press on with the investigation.
Postby manga_blue » Fri Mar 06, 2015 7:58 pm
Near the bottom of the door frame, below the D, is a rubber block which is designed to stop door rattles. They last about 10 years and then start breaking up. You can buy replacements from Mazda, amayama, mx5parts or rockauto.
RS2000
Postby RS2000 » Sat Mar 07, 2015 11:49 am
Before you remove the door lining, check the tightness of the 3 nuts on the underside of door.
simie2014
Postby simie2014 » Sat Mar 07, 2015 12:23 pm
Seems the door rattle may be the battery. The bracket holding the battery is not fixed. The bolt has been snapped off AND an easy out used to get the bolt out has snapped too! Bugga. Any suggestions?
simie2014
Postby simie2014 » Sat Mar 07, 2015 12:31 pm
Three nuts on underside of door. Will do
simie2014
Postby simie2014 » Sat Mar 07, 2015 5:39 pm
Seems that the rattle WAS the battery. Fixed the bracket by drilling another hole. Took Max (Mx5) for a fang. Rattle has gone. Thanks for all those who contributed. Cheers
