strut tower brace torque specs
Technical Guidance for doing those Tricky Jobs
Moderators: timk, Stu, zombie, Andrew, -alex, miata, PUR157
Garido
Postby Garido » Thu Mar 05, 2015 5:52 pm
Hi folks,
I have some front and rear mazdaspeed strut tower bracing I'd like to install. Anyone got an idea on torque specs. While probably don't as sensitive as rebuilding an engine or diff I don't want to destroy a thread or have them too loose.
Thank you all ^^
Rolley
Re: strut tower brace torque specs
Postby Rolley » Thu Mar 05, 2015 7:15 pm
I reckon they will be the same as if the brace was not fitted so "Upper shock mount plate bolts" in the suspension section of this shoud work just fine.
http://www.miata.net/garage/torque.html
Luke.
Postby hks_kansei » Fri Mar 06, 2015 11:56 am
Same torque as stock.
It's not a lot of torque they need, I just wind them until they reach the bottom out, then do another 1/4 turn or so.
Garido
Postby Garido » Fri Mar 06, 2015 1:08 pm
Kind thanks to both for their help. Will let you know how I go but should be fairly straightforward.
Postby manga_blue » Fri Mar 06, 2015 8:08 pm
They'll work just as well with blutack.
r3395
Postby r3395 » Thu Aug 13, 2015 3:51 am
Use a ring spanner 1 handed dont go crazy will be ok
Return to “MX5 Technical Guides”
Users browsing this forum: No registered users and 28 guests
