anyone know the right size spacers for factory 5 spoke 16" (2001) on a 1991 NA?
Im thinking 20mm though would like to be sure.
Bolt on Spacers for Track - Yes or No
Re: Bolt on Spacers for Track - Yes or No
There is no right/wrong size.
The wheels will fit without any spacers, it's just matter of deciding how much further out you want the wheels to poke and buying spacers in that size.
- Vehicle: Non MX-5
why would you spend $200 on factory 5 spoke NB rims, then spend another $200 on spacers? should've just spent $600-$800 and brought the correct offset rim.
- greenMachine
Why spacers at all? NA and NB have same suspension, may be a bit of difference at the guards (rear?), but I would have thought that spacers would make that more problematic, not less?
cause i spent $150 on NB rims with near new rubber
and they are some of the lightest 16s around! also they look factory which i like too. that and spacers should only cost me $100 or so.
I just want a bit of a wider track.
A 20mm alloy spacer will also add about 800g-1kg. Still got a light wheel?
Danny wrote:A 20mm alloy spacer will also add about 800g-1kg. Still got a light wheel?
yup.
- KevGoat
Sage wrote:Danny wrote:A 20mm alloy spacer will also add about 800g-1kg. Still got a light wheel?
yup.
16" NB8B 5 spoke, 205/45/16 ...
15" Racing Hart, 195/50/15 ...
- KevGoat
Just for reference ...
SE 17" Racing Harts, 205/40/17 ...
- Vehicle: Non MX-5
16.5kg for 16x6.5 NB rims. that aint light.
my 18x7.5s weigh 18 flat with tyres. bet you cannot put 225s on the 6.5 wide rims.
my old ms-01r rims weight 7.2 each, and about 14 with tyres.
how much does a 16x6.5 nb rim weight without tyres? 7-8kg? if not, then meh...
Last edited by project.r.racing on Fri Feb 27, 2015 6:22 pm, edited 1 time in total.
- Vehicle: Non MX-5
$100 for 4 bolt on 20mm spaces? with 16 bolts included?Sage wrote:cause i spent $150 on NB rims with near new rubberand they are some of the lightest 16s around! also they look factory which i like too. that and spacers should only cost me $100 or so.
- KevGoat
project.r.racing wrote:how much does a 16x6.5 nb rim weight without tyres? 7-8kg? if not, then meh...
According to http://www.miata.net/faq/wheel_weights.html and a Google conversion, they're 7.03kg ...
Edit: by comparison, these (Buddy Club P1 15x7 wheels) are 4.65kg naked ... (no affiliation btw - just wish I had spare cash to buy them...)
- Vehicle: Non MX-5
P1s are good rims. I had a set about a decade ago.
