17 inch wheel options
chops
Postby chops » Wed Feb 25, 2015 11:50 am
A mate of mine has an SE which runs AP racing brakes with 330mm rotors I think and requires 17 inch wheels to clear brakes. Looking to replace the slightly bent and abused factory Racing Harts. The car will be run at the track and currently runs V70 205/40/17 and will probably continue to do so. Looking to see what spec/brand other people run or anyone with a bit of offset/width advice is welcome.
Re: 17 inch wheel options
Postby hks_kansei » Wed Feb 25, 2015 12:46 pm
It's as simple as choose a wheel you like the look of.
Check if it's available in the specs you want.
Buy 4 of them.
The 949 racing wheels seem a common choice, and I seem to recall them being available in a 17inch diameter.
Postby Lokiel » Wed Feb 25, 2015 1:56 pm
The 17" 6ULs are for the NC.
949racing designed the 15" 6ULs specifically for the NA/NBs.
IDK if the 15" 6ULs will clear your brakes though - they do clear my Wilwood front brakes and rear "Big Brake Kit".
OP: Tell your mate to switch to 15" rims for trackwork, they're lighter, there's more tyre choices available and they're cheaper - all important factors for trackwork (especially tyres since they're consumables).
PS: I toned this down quite a bit from what I intended to write regarding those 17" Racing Harts boat anchors.
Roadrunner
coyotes after you
Postby Roadrunner » Wed Feb 25, 2015 1:56 pm
You could see if Chris at MX5parts can get in these from Goodwin racing. Under 7kg.
http://www.good-win-racing.com/Mazda-Pe ... msmcs.html
Exchange rate could be a killer though.
Goodwin racing has a good guide of what 15's etc fit over big brakes too so if he does want to go to a smaller rim there are options :)
MeepMeep
MattR
Postby MattR » Wed Feb 25, 2015 3:17 pm
Plenty of 17" wheels that will work on your car and won't be boat anchors, no matter what some others may say.......
With 330mm rotors you won't be dropping the wheel size to 15" wheels anyway and 16" tyres are harder to come by than 17" tyres in general.
Look for a good brands of wheel, though the 4x100 PCD may limit you a little. I would recommend brands like Enkei, or Koya or even Rota as I know people who have used all three brands on the track and haven't died yet..... :roll:
Personally I use Enkeis in 15" and 16" on my NA6, I have used Enkeis on my S14 in 17" and will be buying Koya wheels in 18x9 for my S14 race car with the advantage that I can get the wheels machined up to suit the offset I need exactly for the car and to front and rear if required. They are also reasonably light and seem to be very good bang for your buck.
Here is a link to the Koya website:
http://www.koya.com.au/
And a link to the CR Tek wheel in 17" which you cab get custom offset and drilled to suit your PCD:
http://www.koya.com.au/cars/cr-tek-1718big-brake-compatible/
And a link to the semi forged wheels in 17":
http://www.koya.com.au/cars/sf02-17%e2%80%b3-semi-forged-custom-fit/
chops
Postby chops » Wed Feb 25, 2015 5:26 pm
I was struggling finding much in 4x100 and 17
the Koya racing look interesting especially with choice of offset. Can anyone tell me standard specs for the Racing Hart's, can't remember if they are 7 or 7.5 wide and what the offset is?
Roadrunner
coyotes after you
Postby Roadrunner » Wed Feb 25, 2015 10:15 pm
Racing harts are 17x7 et40
MeepMeep
chops
Postby chops » Thu Feb 26, 2015 9:52 am
thanks
so you would think 17x8 with about 35 offset would work with a 205/40/17
project.r.racing
Postby project.r.racing » Thu Feb 26, 2015 10:36 am
chops wrote:I was struggling finding much in 4x100 and 17
are you looking blindfoded? haha
it is a pretty common size. before most small cars went to 5x114.3. so from about 1900-2005 you'd pick them up anywhere. all wheel shops still have them. loads on ebay. loads on yahoo japan.
Roadrunner
coyotes after you
Postby Roadrunner » Thu Feb 26, 2015 3:27 pm
I'm thinking he may have mean't "I was struggling finding much 'that I liked' in 4x100 and 17"
I had a good hard look before spraying up my Racing Harts and a lot of designs are gross (*to me) or in the 'insane' level of cost.
edit: Also why have I never heard of Koya?? Some of those look great! (and come in white :D)
Will remember them if I ever decide to change.
MeepMeep
MattR
Postby MattR » Thu Feb 26, 2015 3:40 pm
Because they are a relatively new comer to the Australian market, and haven't had the flat brimmed internet fame that Rota has...... :lol:
Postby hks_kansei » Thu Feb 26, 2015 5:06 pm
MattR wrote:Because they are a relatively new comer to the Australian market, and haven't had the flat brimmed internet fame that Rota has...... :lol:
WHat?
I've been seeing Koya wheels on Silvias since the early 2000s
The Koya Driftek was for a time the default wheel choice for them almost.
project.r.racing
Postby project.r.racing » Thu Feb 26, 2015 5:41 pm
Koya ain't new.
MattR
Postby MattR » Thu Feb 26, 2015 5:50 pm
For an old bloke like me, that's still relatively new...... :lol:
I'm used to old school wheels no longer easy to get like the Rebel Wheels from Unanderra near Wollongong, or the proper Simmons wheels or Mawer wheels, or the original Hotwires and so on.
Or the original Minilites, made out of magnesium and scary expensive nowadays in a 15x8 with proper offsets for proper old school muscle cars.....
The American
Postby The American » Thu Feb 26, 2015 7:00 pm
I have a set of BuddyClubs In 17x7 4x100 for sale :-)
