Tow Vehicle, on the cheap..
PeterB
Re: Tow Vehicle, on the cheap..
Postby PeterB » Wed Feb 04, 2015 9:37 pm
I have towed car trailers, horse floats and caravan for 20 years with EB, ED, AU Falcon wagons, EL XR6 and currently BA MkII Futura sedan. All 6 cylinder petrol, autos.
Good transmission cooler and tow in Performance mode a must. Never had a failure and the fuel consumption figures above seem reasonable. Slow it down a bit and it improves.
Just done 13,000 km to Perth and back with caravan on BA with no worries. Averaged about 15l/100 km, but does better with car trailer as better aero.
I would recommend wagon or ute with leaf springs for better load bearing as sedan IRS wears out bushes.
Peter B
MX5 free for present
Postby manga_blue » Wed Feb 04, 2015 10:11 pm
My BF II has Ford factory gas. Not really happy with it compared to what I've heard about better quality systems fitted aftermarket to multi-point fuel injected engines. The Ford unit uses a single injector in the throttle body. It is pretty gutless, feels choked, often backfires on starting and sometimes rough idles. I think Ford scoured the world for the cheapest system they could find - this one comes from Belgium.
Fuel consumption is 14-16 l/100 highway unladen and 22-24 l/100 highway towing.
LPG Tanks need removal and full inspection (pressure testing?) at 10 years - mine failed at 7 and had to be replaced. Stepper motor assembly requires draining and filter changes regularly - not easy when half the fittings seize up.
Have a browse through the Falcons section on fordforums at http://www.fordforums.com.au/forumdispl ... 94d5d&f=30
Postby manga_blue » Wed Feb 04, 2015 10:18 pm
More info on LPG tank testing here: http://mobilelpgtanktesting.com.au/lpg- ... sting.html
evil_weevil
Postby evil_weevil » Sat Feb 21, 2015 6:03 pm
Coming to part late
My 08 Santa Fe tows great, MUCH better than my old vx commodore but that's just common sense!
Mines diesel but now they are around 15-18k still
viewtopic.php?f=73&t=62834
Return to “MX5 Motor Sport”
