NitroDann's Long Awaited Garage Thread
Re: NitroDann's Long Awaited Garage Thread
Wow. Number plate should be FAR-RRR because that's what I'd be saying if in the passenger seat!
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
You using the standard 6 speed? I had my motor detuned to keep the box alive. Are you guys looking into gearbox options?
Its limited to 280 ftLB at the wheels (calculated back to the engine). What did yours make? Even more right?
Should be okay. It really needs harder engine mounts though.
For those not on my facebook page, heres a sneak peak of some work in MX5002's NB8B, more pics on my page, www.facebook.com/NitroDann
- beavis
- Vehicle: NB8B - Turbo
how cool is bumper cut out.
best thing to do to a miata.
- Dweezle
Does it actual work in reducing drag ??
The parachute effect ??
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- mx5002
I haven't put it in a wind tunnel yet. I might have a minimal effect atm. Once I make a diffuser it will be beneficial.
Besides all that I love the look combined with the
duck tail:)
duck tail:)
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64
Marulan 47.01
Wakefield 1.09.64
I reckon it does make a difference at higher speeds, I did the same to my NB and that entire strip normally hangs down in the breeze...Any real advantage to be gained would come with managing airflow under the car though.
- lightyear
- Infinity & Beyond
NitroDann wrote:Its limited to 280 ftLB at the wheels (calculated back to the engine). What did yours make? Even more right?
Can't remember the numbers exactly. But before he put on the extra external waste gate it was making about 450hp at 4000 or so rpm. He got it down to 380hp at 7000rpm. Also even less power/torque depending what gear it is in.
All pretty useless in a car that just sits in the garage.
450@4000rpm would need around 40psi..?
- lightyear
- Infinity & Beyond
I found the txt.
374hp@6000rpm 18psi.
380lbft at full boost.
292hp at 5700rpm.
270lbft at min boost 7lb. Turbo rated for 370hp - maxed out compressor. Inj maxed out too. Rev limit at 7000.
He said 330hp is about the limit for the trans.
292hp at 5700rpm.
That's a 1.9L also yeah?
- lightyear
- Infinity & Beyond
It's a 1.8 still as far as I know.
An interesting photo I took that shows the behavior people talk about with stockish SE's.
You can see the low (yellow) line starts very low hp, and when the ecu goes open loop after emmissions testing rpm we get a bit of turbo HP for less than 1000rpm then hit the low redline.
I havnt seen dyno's for these cars just dríven them but I now have this one to show people. This car had the common ebay larger intercooler and a full 2.5" exhaust.
Cool huh
Cool huh
PM's replied.
Yellow line SE performance mods:
2.5" magnaflow exhaust
Justjap FMIC
Purple line SE performance mods:
3" NitroDann exhaust
Justjap FMIC
NitroDann Intake
Haltech Elite1500 with NitroDann PnP harness, NitroDann EBC and NitroDann tune
Justjap FMIC
Justjap FMIC
NitroDann Intake
Users browsing this forum: No registered users and 328 guests
