1.8 harness in 1.6 for budget turbo build???
- Learner Driver
ok so im doing a budget turbo build on my 92 mx5 and was just curios about a few things.
can i run the 1.6 engine on the turbo 1.8 ecu from the gtx and harness from the 1.8 mx5 to use hot wire afm and vtps? if not what other afm can i use?
thanx in advance
thanx in advance
- bartmanftw
Re: 1.8 harness in 1.6 for budget turbo build???
It would be much easier and run a lot better if you just went for an aftermarket ecu instead.
- Learner Driver
fair enough but being a first yeah apprentice mechanic money is slim and i just wont it to work till i can afford and aftermarket ecu
Interesting idea but agree with Bart. Can get 2nd hand MS2 ECU for 500 and not have to mess with the harness, ditch the AFM (which saves you money)
Doing it right the first time actually saves you money and gives you more road time.
My advice is to keep saving, build it right and then show it off to your mates
- bartmanftw
Yeah do it once do it right. In the long run you'll end up saving yourself a headache and some cash.
NitroDann builds NA6 turbo cars for breakfast. Worth while checking out his work so you know how it should be done.
Good luck and keep us updated
- Learner Driver
thnx for the advice guys. might have a look around for a mspnp and have a look at nitrodans work.
im going to be running td05-16g, black top ingectors from the gtx (360cc) manifold and downpipe i baught from a guy that no longer wanted to turbo his mx (still it packaging)with full stainless 2 1/2inch all the way through, FMIC second hand from a merc sprinter van, boost t and wideband o2 and whatever ecu i decide to run with
Sounds perfect! Heaps of peeps use the rx8 injectors 420 or 440 cc being a more modern design they have some advantages. Cost around 440 for a new set but if you have the 360's suspect they'd be fine running on PULP.
Now I'm excited for you
- Learner Driver
haha thanks
a friend of mine is going to run rx8 injectors in his.
you wouldnt happen to know how hard it is to tune a megasquirt?
im also planning on running around 10-12 psi
- Learner Driver
also sticking to my budget i picked up the injectors for $100
i couldnt be happier
miatakid wrote:you wouldnt happen to know how hard it is to tune a megasquirt?
Sorry, no. I'm also new to the MS and my build hasn't progressed that far just yet.
Still doing fiddle bits.
Have to learn and get it sorted over next couple of months.
miatakid wrote:haha thanksa friend of mine is going to run rx8 injectors in his.
If you do your research, it isnt really that hard.
Better off getting a proper dyno tune before running more than 6-7psi, so you dont blow you engine up.
- bartmanftw
Tuning megasquirt is fairly simple and the autotune feature makes it super easy to tune the fuel map. Might take a while to learn how to set up idle control ect propely but there are heaps of guides out there on the interwebs. No need to go to the dyno even if you're running over 8psi but obviously you'd be able to get a better tune if you did and be able to set up the spark map properly.
I'm currently running rx8 injectors on mine and had no issues getting them to work properly.
- Learner Driver
hmmm. ok im deffinatly leaning towards getting a megasquirt and it seems like much less of a headache! currently the car is being used as my daily and im just in the process of piecing together all the bits i need before i take it off the road and start putting it all together! i still need to pick up my injectors, get a wideband o2, vtps, air temp sensor, and when everything is bolted on take it to a shop to get some fully sick custom cooler piping
- Learner Driver
aaaaaand i baught myself a mspnp
