My SE is not well.
Col99
My SE is not well.
Postby Col99 » Fri Feb 06, 2015 7:43 pm
Hi All, Hope someone can help me with some advice. I have a 2004 Se and a month or two ago I put a BEGI CAI on it and it was going well apart from the under bonnet whooshing noises, BOV I think.
Yesterday the turbo started to whistle a bit when I gave it a bit of throttle, now it runs very poorly, no power and idles like it has a very lumpy cam in it. Any suggestions. I am hoping the turbo has not given up the ghost.
I am in Perth Wa and suggestions as to who to take it to would be appreciated as well.
Col
Re: My SE is not well.
Postby bruce » Fri Feb 06, 2015 8:03 pm
I bet a pipe/connector has fallen loose.
Juicy HiC
Postby Juicy HiC » Fri Feb 06, 2015 8:06 pm
When I did mine the same thing happened. Check the connection going from the turbo to the intercooler. That's what popped off 1st on mine. Otherwise check the connection on the throttle body inlet.
Col99
Postby Col99 » Fri Feb 06, 2015 8:53 pm
Thanks for the replies, had another much closer look and found that the fasteners that held the BEGI pipe to the turbo has worked loose, obviously not tightened properly. My bad, all good now.
thanks again
Col
Postby Okibi » Sat Feb 07, 2015 12:49 am
Glad it was an easy and cheap fix.
