Budget NA6 supercharge build
Re: Budget NA6 supercharge build
Postby Magpie » Fri Jan 23, 2015 8:16 pm
Another option is to install 4 x bonnet pins and just lift it on and off.
wade
Postby wade » Sat Jan 24, 2015 7:58 pm
So I installed the RRFPR today along with larger injectors
The fuel rail adapter was a bit of a prick, new holes needed to be drilled and then as it was leaking I had to cut the end piece off the OEM fuel regulator and linish it flat to make an adapter, in the end it sealed
Now I'm just waiting for the adapter for the idle control valve then I can do the timing......
Postby hks_kansei » Sat Jan 24, 2015 8:26 pm
wade wrote:
hks_kansei wrote:For struts I'd just go to a wrecker with a tape measure.
Work out how big/small you need, then scour the yard for cars with the struts attached (best bet is the boot of hatchbacks and modern sedans, they often have smallish struts there)
^^ like
Need screw in balls though :-(
either see if you can buy them seaprate.
or, see if the car has them and take them too.
Good option for the balls is to find a ute with a hard lid, the lids were all pretty much aftermarket, so pretty much all of them had the screw in balls (where OEM struts often had the balls welded)
sailaholic
Postby sailaholic » Sat Jan 24, 2015 10:56 pm
Be careful what you get the struts off! Too strong a strut will leave your bonnet bowed when closed.
wade
Postby wade » Mon Jan 26, 2015 2:43 pm
Managed to move the bonnet thing to the other side.......
Also did more work on the heat shield ..... Still needs a bit more
wade
Postby wade » Sat Jan 31, 2015 4:00 pm
Fitted up the pipe for the IC valve
Then warmed it up and was going to do the timing when I noticed a massive amount of fuel under the car :-S ....... Lucky that nothing went bang.....car was on the ground so I didn't notice it for 5 mins or so
At first I thought it was the fuel rail adapter that I fabricated so off I went to rocket parts and found a proper one. Came home and installed it and it was still leaking :-(
Turns out it was the injector on cylinder one leaking...... Strange as they were fine the other day and have all new bits of rubber.
I reseated them and sealed them again and they were fine...... Oh well, fuel adapter needed to be done anyway
Did the timing and adjusted the fuel pressure to 43 psi took it for a drive and it felt like it was a little starved for fuel, so I upped it to 56 and when I took it for another drive it went a lot better...... Then the Idle control valve pipe split and so I put it away
All in all a successful day...... Another step closer
Need to change the oil in the charger and fix the pipe and probably some clamps whilst I'm at it
I'll post up some vid when I get a chance to edit it a little.
wade
Postby wade » Sun Feb 01, 2015 11:11 am
So here is the vid of the test
Does anyone know why I would be getting what sounds like belt slip when I lift off??
http://youtu.be/hnbwFMXOX-Y
wade
Postby wade » Thu Feb 05, 2015 9:08 am
^^^^ no thoughts re the noise ??
speed
Postby speed » Thu Feb 05, 2015 5:44 pm
My thoughts were dodgy guesses so I didn't post.
Since no one else has responded, here they are.
You mentioned SNC issues earlier. Is the crank pulley wobbling? How bout your engine mounts, is one worn out?
Just trying to think of things that result from inertia.
Also guessing it only happens under load?
speed
Postby speed » Thu Feb 05, 2015 5:46 pm
Forgot to ask if the tensioners spin freely but you've come this far so you're obviously not an idiot :)
wade
Postby wade » Fri Feb 06, 2015 7:38 am
Thanks Speed, I suppose that it could be the SNC issue, but I don't think so, tensioner spins freely
It seems to happen when I lift off the accelerator after load, could it be the little black pressure release valve?
It almost feels like the boost is still trying to spin the supercharger and the engine rpm is slowing, causing the belt to slip, but I though the release valve would prevent this
Suppose I'll just live with it, another noise to the orchestra of noises now emerging from under the bonnet :-D
speed
Postby speed » Fri Feb 06, 2015 8:43 am
You are further along than me and I just don't have the experience to comment on the pressure relief valve.
Hopefully someone else can add some meaningful explanation.
wade
Postby wade » Sat Feb 07, 2015 6:33 pm
I made up a fuel pressure calculator to try to ensure that I don't bin the motor, because I couldn't find anywhere online where all the formula were consolidated
I posted it up in the thread where I asked the question.
viewtopic.php?t=67015
I have a question for one of the wiser heads
Q: I've installed injectors off a 1.8 99-00 which are rated at 256 @ 43.5 psi yet are designed to run at 60 psi (with in tank fuel regulator with no return line)
Do these injectors need to run at this psi to work and should that therefore be the baseline psi in the model rather than the rated 43.5 psi ??
And how much head room (if any) do I need ?
Any help gratefully appreciated !!
speed
Postby speed » Sun Feb 08, 2015 12:59 pm
Hi Wade, I'm having trouble getting the right size belt. I'm guessing you have AC and no PS, if so is your belt 1325mm in length?
From there I'm told the next available size is 1400! I thought I needed a 1330 or maybe 1335 but am now uncertain...
wade
Postby wade » Sun Feb 08, 2015 3:53 pm
I'm not sure how to measure it with it on :-(
but I took a photo :-)
Maybe 1345 ??
