My NC recently came up with the airbag error B1055 (two long flashed *break* then 3 quick flashes).
Ive tried wriggling the connector to the airbag and have tried to disconnect the battery but that has not cleared it.
I cant remove the plug from the airbag as i have no idea and dont want to break a connector.
Has anyone successfully cleared this airbag error?
Or maybe even knows how to remove and clean the connectors?
NC Airbag fault
NC Airbag fault
Regie wrote:spending my money again Trevor
- JBT
- Regie
- Vehicle: NC - V8
Re: NC Airbag fault
ill catch up with you over the weekend Trev and have a look at it
- JBT
Re: NC Airbag fault
Try this: http://www.mellens.net/mazda/Mazda-Miata-2008-2009/airbags.pdf
See pages 12-16.
See pages 12-16.
- Dan
Re: NC Airbag fault
Good luck with it Trev, my Evo popped an airbag light the other day. Super annoying!
Re: NC Airbag fault
Chris said it could be the passenger seat... So I'll check that
Worse is that I have to disconnect the battery and the car takes an agggggge to stop idling at low rpm's
Re: NC Airbag fault
It's all related to the 2.5 install. If you just take it out and put a 2.0 in...all will be good again.
Promise
Promise
Rob
- JBT
Re: NC Airbag fault
cwto24 wrote:Chris said it could be the passenger seat... So I'll check that
Look at the attached.
