Kumho KU31 and HS51 tyres
project.r.racing
Re: Kumho KU31 and HS51 tyres
Postby project.r.racing » Sat Jan 17, 2015 6:25 pm
HS51 is not the replacement for the KU31. KU is a ultra high performance tyre. HS is a Solus, eg grand touring and street tyre.
MrRevhead
Postby MrRevhead » Sat Jan 17, 2015 6:31 pm
I just got a set of KU31's fitted yesterday.
They are around, you just need to look for them.
As said before, look for parallel importers.
What project says above is true, although the line many tyre places are using is HS's are the direct replacement. Possibly to suck in the unknowing. I have also heard from one retailer that they replaces KU's with HS's
because they offer better wear on the out end of the tyres....
KU23's are also out there, not sure how they compare to the ever popular 31's though.
ricky-pinky
Postby ricky-pinky » Sun Jan 18, 2015 7:56 pm
My local Bob Jane tyre guy tells me that the KU39 is the replacement for the KU31 - same performance characteristics.
The KU31 is a unidirectional tyre whereas the KU39 is an asymmetric tyre.
Postby Lokiel » Sun Jan 18, 2015 10:30 pm
KU39s are track tyres (soft) so they're wear VERY quickly for DD and they're more expensive than KU31s.
Your Bob Jane tyre guy is either a moron or just wants to sell you tyres that he knows will wear quickly.
THey're a great track tyre in the dry - not so much in the wet.
bensale
Postby bensale » Sun Jan 18, 2015 10:32 pm
^ You're thinking of KU36 Lokiel.
Can highly recommend Michelin PS3's, they're the perfect performance road tyre. You'll spend a little more, but well worth it.
www.othersideproductions.com
MrRevhead
Postby MrRevhead » Mon Jan 19, 2015 7:54 am
ricky-pinky wrote:My local Bob Jane tyre guy tells me that the KU39 is the replacement for the KU31 - same performance characteristics.
KU39's are only available in 16"+ though.
Postby Lokiel » Mon Jan 19, 2015 11:13 am
bensale wrote:^ You're thinking of KU36 Lokiel.
DOH - I've made that mistake before!
