Howdy folks.
Say I wanted to do the track car windscreen removal thing... apart from cutting it off with a grinder and welding up the holes left behind, is there anything else I need to consider? Am I removing any structural rigidity that I need to put back with some bracing or whatever?
Lopping off the windscreen surround
Re: Lopping off the windscreen surround
Do you have a full cage?
Nothing there as far as I know.
most of the rigidity is in the main shell, and even so, behind the dashboard is a big thick steel bar that would provide strength.
So yeah, if it's what you want to do, start hacking away.
(obviously if it's an NB remove the airbags before you start cutting as theymay go off)
Just a tall boy roll bar at this stage
Its a na6
Skinny Jim wrote:Its a na6
easy then, kick out the window and grab the grinder.
I would not cut the windscreen off without having a full cage. Is it still road registered?
Currently unregistered. I was thinking about putting it on club reg but vicroads have just announced changes to the club reg scheme which means I'd have to do a full road worthy to get it back on the road... Hence I'm thinking of turning it in to a track toy as it would mostly only ever get dríven to and from the track even if it was regoed. It'd be cheaper just to buy a tow bar as I have a tow vehicle and trailer already.
Wasn't there a company doing a bolt in cage? In Sydney?
It won't be entered in any competitive events so I'm not fussed about meeting any regs, other than safety regs. Just track days, for fun.
This hurts and if anybody at work found out I said it, but, THINK SAFETY!
- mx5002
The windscreen and surround in an na6 would have little to no benefit in a rollover except getting in the way!
Lop it off I say...
Check out blackbird fabrications in the states. They have a face space page too. They have a few cool windscreen less mx5's with rollbar ideas that may help
Lop it off I say...
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64
Marulan 47.01
Wakefield 1.09.64
- PeterB
- Vehicle: Non MX-5
There are a number of screen free NA6 track cars floating around.
If you want to go that way :
Remove front screen and fill in holes. Remove windscreen wiper, motor etc.
Remove side windows, wiring, switches, etc as they now serve no purpose (more weight saving).
Fit a small aero screen as you will be buffeted like crazy without it.
Ensure the dash top is well bolted down, as there was a nasty incident at Bathurst a few years ago when the dash cover tore off and wrapped around the driver.
As a minimum fit a diagonal from centre-top of rear bar to front floor in case you go under a fence or something so it pushes wire up over you. A full cage would be preferable.
Fanta's (NA6 Production Sports) windscreen free race weight was 820 kg in Production Sports spec with no carpet, roof, etc and only race seat.
She was rigid to drive and was very agile with the low weight (1.09 at Wakefield Park with 1600 supersprint spec, and 1.05 in full Prod Sports spec with Brian Anderson). It is a different driving experience out in the elements, feels more like a real race car.
My next NA6 with roof and windscreen was more user friendly in Canberra/Goulburn weather !!!!!
Peter B
MX5 free for present
