NB seat belt beep
Roadrunner
coyotes after you
NB seat belt beep
Postby Roadrunner » Mon Jan 12, 2015 10:14 pm
So I have successfully disabled the annoying beeping when the key is in the ignition and the door is open. As simple as a connecter in the steering column (I can now clean inside the car with the radio on and the door open and not go insane)
I was hoping it would disable the seat belt warning beep too but no luck.
Is this possible?
I don't want to disconnect the beep all together as it's good when I accidentally leave the parkers on.
I know when I don't have my seat belt on, I don't need the car bleeping away every time I sit in the car with the ignition on
MeepMeep
ManiacLachy
Re: NB seat belt beep
Postby ManiacLachy » Tue Jan 13, 2015 8:26 am
Doesn't the seat belt alert beep stop after a few seconds?
Roadrunner
coyotes after you
Postby Roadrunner » Tue Jan 13, 2015 11:37 am
6 beeps. 6 loud annoying beeps :lol:
MeepMeep
pezchops
Postby pezchops » Tue Jan 13, 2015 1:23 pm
have a look under your drivers seat and unplug it
Roadrunner
coyotes after you
Postby Roadrunner » Tue Jan 13, 2015 3:13 pm
The plug to the seatbelt stalk? I'll give it a go but won't that mean the car will think the seatbelt is undone all the time?
MeepMeep
Nevyn72
Postby Nevyn72 » Tue Jan 13, 2015 3:16 pm
Roadrunner wrote:The plug to the seatbelt stalk? I'll give it a go but won't that mean the car will think the seatbelt is undone all the time?
There will be another one to the seat base, the plug is just under the front edge (blue wire). :wink:
EDIT: I just had a thought.... disabling the seat base sensor may interfere with the operation of the airbags and/or seat belt pre-tensioners in the case of an accident.... :?
Roadrunner
coyotes after you
Postby Roadrunner » Tue Jan 13, 2015 4:25 pm
And that is what I would like to avoid!
Thinking a bit more about it, The metal seatbelt buckle bridges something in the stalk, I might have a look and see if I can close the circuit in the stall so it thinks the belt is buckled all the time.
This would avoid any airbag issues.
Was kinda hoping it would be as simple as disconnecting a plug lle the ignition/door beep
MeepMeep
Postby hks_kansei » Tue Jan 13, 2015 6:19 pm
Maybe the 8b is different, but my NB8A won't beep if the belt is unreeled a few inches, regardless of if it's clicked into the belt buckle.
The buckle 100% doesnt have any switch in it, as I removed my NB buckle and replaced with an NA one, the seatbelt beep still works.
Roadrunner
coyotes after you
Postby Roadrunner » Fri Jan 16, 2015 8:43 am
Tested that last night. Even with the belt pulled all the way out still beeps. Stops as soon as you click it in the buckle.
Had a quick look at the cabling and all and decided to put this on in the too hard basket :frown:
MeepMeep
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Mon Jan 19, 2015 3:35 pm
There is a plug next to the steering column under the dash, has a wire that comes from the ignition switch, just have to unplug it.( it's not the wire that comes from the sensor ring for the ignition key)
Roadrunner
coyotes after you
Postby Roadrunner » Mon Jan 19, 2015 4:10 pm
Is that this one here Lou?
Two green wires to a white plug on the left side of the steering column?
If so this stopped the door beep with the key in the ignition but not the seatbelt warning.
From what I remember the only other plugs were the Airbag and the ignition itself.
I unplugged the plug under the seat which stopped the beep but not sure if this effects airbag operation, plus the dash light was constantly on too.
MeepMeep
kalt
Postby kalt » Mon Jan 19, 2015 6:07 pm
Buckle up first before you sit down and turn the ignition ON.
Bit of a hassle, it might not be comfy at first, but it beats the annoying beep
Owning a fast car is easier than driving a car, fast.
For sale
NB8 Factory Airbox
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sat Jan 31, 2015 7:51 am
If you unplug the cable that goes to the buckle and the air bag light on the dash goes off after you start the car then you have no problem.
Roadrunner
coyotes after you
Postby Roadrunner » Tue Feb 03, 2015 9:30 pm
Hi Lou,
Unplugged the cable under the seat and yes the airbag light turns off after the car starts.
Now beep free, the way to be :)
MeepMeep
Users browsing this forum: No registered users and 30 guests
