Pulling ABS fuse(s) for the track
- davekmoore
Spent this arvo trying to isolate the parasitic battery drain in my car so got familiar with the fuses.
A 20a fuse under the bonnet is allocated to "antilock brake system" and a 10a fuse by the driver's right knee says "supplementary restraint system, antilock brake system".
So does pulling the 20a disable the ABS, or do both need to be pulled? Or does the 10a just control airbags, seatbelt pretensioners and/or any other features?
Reason I ask is that with decent front brakes now on the car I might want to only use ABS in the wet .
- mattyredlocks
Re: Pulling ABS fuse(s) for the track
Quick - before this thread turns into an ABS vs Non-ABS dirt slinging match!
I'll just keep my opinion of ABS removal to myself (*cough* ABS saved my arse a handful of times *cough*), but from memory reading a prior thread, it's just the one fuse to disable ABS.
I think insurance can become an issue though (both normal and CTP), as you will have intentionally disabled a safety system for the car they insure.
- davekmoore
I would never disable ABS or any other safety system for road use.
I, too, prefer this thread to only be about which fuses to pull for the track please, and not to be about whether ABS is "better".
- Dweezle
Not sure in MX5s but in my Clio if you pulled the fuse you lost the correct distribution between front and rear pressure.
It made the car far worse.
Heavily rear biased.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- mattyredlocks
My service/repair manual doesn't say much about disabling it (wonder why), just that if the "check airbag" light comes on, to replace the fuse and take it to a dealer if it stays on after that.
If you're at the track and under a CTP rally/race extension (that's they way we do it on the QLD MX-5 club days for road registered cars, anyway), you might still want to check what the rules are - technically you're still covered by CTP under one of these extensions, though to what extent I don't pretend to know.
- davekmoore
Dweezle wrote:Not sure in MX5s but in my Clio if you pulled the fuse you lost the correct distribution between front and rear pressure.
Heavily rear biased. Sent from my SM-N9005 using Tapatalk
The plot thickens.
Electronic Brakeforce Distibution eh?
Perhaps this is why some MX5ers add proportioning valves for if they disable the ABS?
And perhaps I'd be better advised to stay out of the ABS zone on the track?
- mattyredlocks
I'm curious, have you actually had ABS kick in, in an unfavorable way at the track?
I only ask because I have, and I've welcomed it. Stopped me locking and wearing big flat spots into my tyres a couple times. What advantage do you have *not* having ABS?
Not trying to have a go here, I'm mostly just curious. I suppose I learnt to drive in cars with ABS, and I've never dríven a non-ABS car fast. Shows my age there.
- davekmoore
I'd be at the opposite end of the age spectrum then.
Happy to keep ABS for in the wet and probably for in the dry, but a little reading (always dangerous) has suggested it might be better for the front Wilwoods if they're not subjected to the 60 pulses per second that normal ABS will give them rather than many more pulses per second they'd get from race ABS (which costs 10s of $1,000s).
The alternative is to avoid heavy braking, but I'm well known for braking heavily, late, and too much, so that would involve changing the habits of a lifetime.
- greenMachine
Got a source for that Dave? As I run ABS with my Wilwoods, I would be interested in finding out why that might be so.
I would say pl the fuse and go for a few laps and see for yourself and don't forget to report back your experience(s).
- davekmoore
greenMachine wrote:Got a source for that Dave? As I run ABS with my Wilwoods, I would be interested in finding out why that might be so.
From the big forum. Didn't save the page references, sorry. The suggestion is that such a slow pulse rate (60 cycles per second) is not good for the longevity of Wilwoods.
There was also a suggestion that a prop valve can be added with the ABS disabled, then you set up the balance, and then re-enable the ABS. This is apparently to avoid the 50/50 front/rear bias that would otherwise exist with the ABS disabled, which even I know would be a Very Bad Thing.
- beavis
- Vehicle: NB8B - Turbo
Dave, I have pulled the single fuse under the bonnet to disable ABS.
- de Bounce
As per beavis quote.beavis wrote:Dave, I have pulled the single fuse under the bonnet to disable ABS.
Done it heaps of times for Motorkhana.
Found I could stop faster than the ABS would allow me at slower speeds (sub 50Kph) either dirt or bitumen.
- beavis
de Bounce wrote:As per beavis quote.beavis wrote:Dave, I have pulled the single fuse under the bonnet to disable ABS.
I'm seeing your old car a lot around Mulgrave.
- de Bounce
That would be it.beavis wrote:de Bounce wrote:As per beavis quote.beavis wrote:Dave, I have pulled the single fuse under the bonnet to disable ABS.
New owner is very happy with her!
Users browsing this forum: No registered users and 62 guests
